Old 12-14-2014, 05:17 AM
71RS/SS396's Avatar
Originally Posted by dhutton View Post
I think they are upside down.
Don
Nope, he's got it assembled correctly.
Old 12-14-2014, 05:27 AM
71RS/SS396's Avatar
Originally Posted by badazz81z28 View Post
Gents,
I got the speedtech crossmember and despite it fitting the frame, the wierd "L-Brackets", go pretty vertical off the frame. This doesnt seem like it will clear the floor. Does anyone have actual expereince using this X-member and possibly photos?
My wife's first gen has one... the vertical brackets pretty much touch the floor but I think this may have to do with the half height body bushings. I plan to eventually replace this crossmember because I don't like the amount of flex it has.
Old 12-14-2014, 05:41 AM
dhutton dhutton is offline
Yep, my mistake.
Thanks,
Don
Old 12-14-2014, 09:33 AM
Don
I hoped so, but I have seen installed photos on the 1st gen and this is how they are oriented. Ben also has pictures posted in the new 2" header post as the same orientation.
https://lateral-g.net/forums/showthread.php4?t=48446
Old 12-14-2014, 09:39 AM
Guys I really need some help. I recently got word that I'm going to be transferred and I don't know what to do for an X-member now.
Old 01-18-2015, 01:19 PM
Z06vette's Avatar
Z06vette Z06vette is offline
Probably too late at this point, but today I just dropped the body (69) onto the DSE subframe with motor/trans installed. The brackets on the ATS crossmember are up against the floor. I have the DSE std height mounts. Tim- what trans cross member do you plan to run on Deb's car?
On a second note- I used the 1" setback mounts, and the 102 FAST intake is against the firewall. So I dropped the sub back out for crossmember and engine stand replacement ...
69 RS LS3/T56
68 firebird vert LS1/4L60E
67 RS LS2/T56
Old 01-19-2015, 09:41 AM
Blake Foster's Avatar
I'm sure hoping the headers I currently have fit. What do most folks use for the tranny X-member?
the ATS one works perfect
Blake Foster
www.speedtechperformance.com
Old 01-19-2015, 09:42 AM
The mounts are supposed to be up at the floor. there should be 1/8 - 3/16 gap but that is all.
Just re red the OP first post and the car is a second gen so that is probably the issue the AST Cross member shown a couple post back is a first gen X Member and the second gen has a different shape floor and the side brackets are shorter. I an thinking that is where the confusion is.
Blake Foster
Old 01-19-2015, 11:07 AM
Z06vette's Avatar
I have the ats x member and the brackets hit the floor on my 69 w DSE subframe, just as Tim mentioned above on his wife's car. As I was tightening the subrame bolts, they got tight & I noticed the brackets up against the floor. Stock height DSE body mounts. Maybe I'm missing something...
69 RS LS3/T56
67 RS LS2/T56
Old 01-19-2015, 11:24 AM
I think part of the confusion comes from DSE saying their second gen subframe uses a first gen crossmember. At least that is my understanding.
Don
