Old 08-30-2014, 06:34 PM
Default 1970-81 DSE Frame "Extras"
I bought a DSE frame, but it appears the motor mounts and steering shaft are sold separately. Being these don't come with the frame, are there better/cheaper components to use? $600 for motor mounts and a shaft seems kind pricey considering the coin dropped on the frame.
Old 08-30-2014, 06:57 PM
Che70velle's Avatar
There is a set of DSE set back mounts for sale over in the classifieds, for like $40.00 shipped. Not sure if these mounts fit your year sub, or if there's even a difference.
Thanks Dad!!
Old 08-30-2014, 09:23 PM
Vince@Meanstreets's Avatar
steering shaft stuff you can get from summit/coleman/speedway
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 08-31-2014, 11:51 AM
Vince do you have any direct points to part #s?
Old 08-31-2014, 04:56 PM
I do at the shop. The shaft is cut to fit.
I'll hit you up Tuesday. What steering column do you have?
Vince
Dealer for
NEVER FORGET -11
Old 08-31-2014, 07:17 PM
Vince
Vince, I'm not sure. Stock 1970 Camaro/non-tilt
Old 08-31-2014, 11:28 PM
ok, i'll send you info tuesday.
Dealer for
NEVER FORGET -11
Old 09-01-2014, 05:40 AM
71RS/SS396's Avatar
The first gen and second gen engine mount kits are different, make sure you get the correct one.
Old 09-01-2014, 07:49 AM
Is DSE the only choice for mounts on their frame?
Old 09-01-2014, 08:43 AM
71RS/SS396's Avatar
Yes, unless you want to start fabbing something. The second gen frame stands are really far back on the crossmember, it actually positions the urethane mount behind the crossmember.
