Old 07-04-2016, 06:53 PM
MillerBuilt's Avatar
MillerBuilt MillerBuilt is offline
In stock!
https://lateral-g.net/forums/showthread.php4?t=49657
Old 07-14-2016, 05:15 PM
brownz brownz is offline
Originally Posted by MillerBuilt View Post
Ordered my kit today. Thanks again Jay for the great customer service. I look forward to installing the floater.
Old 07-14-2016, 08:53 PM
Thank you Brandon. Your support is MUCH appreciated! You're gonna love it
Old 08-06-2016, 11:54 AM
Default FREE Shipping & PayPal This Weekend!!
FREE Shipping & PayPal This Weekend!! (8/6/16 & 8/7/16 - "lower 48" states only)
Old 10-01-2016, 03:46 PM
Default October Special!
FREE Shipping & PayPal through October!! ("lower 48" only)
C6/C7 Hybrid Floater System -
Installs onto any Rear-End that utilizes "Early" or "New Style/Torino" Big Bearing Ford Ends.
That's right,,,, you can use your current rear-end housing, NO welding & simple installation. BOLT-ON!
Advantages:
  • Bolts to your Early OR New Style/Torino Big Ford Housing End (Chevy 10/12 bolt application now available! https://lateral-g.net/forums/showthread.php4?t=52854 )
  • Reduces/eliminates brake “knockback”
  • Eliminates axle deflection
  • Wheel & tire remains intact should an axle failure occur
  • Front or Rear Caliper / E-Brake Cable Positions
  • Utilizes the robust, zero maintenance C6/C7 ZO6 Hub Bearing Unit
  • Utilizes OEM C5/C6/C7 Corvette, and 5th Gen Camaro brake kits
  • Utilizes aftermarket C5/C6/C7 Corvette, and 5th Gen Camaro brake kits
  • Utilizes your existing BAER / WILWOOD caliper & rotor (some restrictions apply)
  • Super compact design compared to traditional style full floaters
  • All advantages of a traditional style full floater without the maintenance
  • Replacement parts available at local GM dealer or local parts house
  • No modifications required to the hub bearing unit as other kits in the marketplace
Note: this applications will add 3/16″ per side to your existing wheel mount surface (based on an existing 2.50″ axle/brake offset)
Fitment: Any rear-end housings that utilizes Early or New Style/Torino Ends
Big Ford Bolt-On “Base Kit” (pictured below)
Big Ford Bolt-On “Base Kit” (pictured above)
Base Kit Includes:
• (2) Billet Steel, C-Series, Hybrid Floater Adaptors
• (2) Billet Aluminum Caliper Brackets
• (2) C7 Corvette, SKF 33 Spline Hub Assemblies
• (1) Install Kit
• (2) Hub Spacers
• (2) Billet Aluminum Hub Cap Seals
________________________________________
PRICED AT - $1,398.00
Add Axles - $400.00
• (2) Hy-Tuf Full Float Axles
Add E-Brake items - $325.00
• (2) C5/C6 Corvette Complete E-brake Assemblies
• (2) C5/C6 Corvette Parking/E-brake Cable Brackets
Have interest?
Have questions?
Need more info?
Distributor Inquires Welcome!
Below pics of the assembled "Base Kit".... (attached Big Ford End is for display purposes only)
Below pics shown with optional C5/C6 E-brake Assembly & E-brake Cable Bracket. These two e-brake items are optional and the system can be run without and added at a later date if desired.... (attached Big Ford End is for display purposes only)
Big Ford "Bolt-On" kit in action!
Old 10-14-2016, 02:33 PM
Dan65SS Dan65SS is offline
Default Axle measurement
Jay-
I haven't gotten the kit installed yet, I ordered it through Tobin, but I am sitting here looking at it and wondering the best way to get measurements for cutting my axle shafts?
I have new axles that have extended splines on one end which allow for cutting to size.
Should I just assemble the whole rear end and brakes and then use my full length axles and see how much is sticking out?
Are there known measuring points we can use to calculate the length once we know what brakes and rear end lengths we have?
I know you provide this: **Note: this applications will add 3/16″ per side to your existing wheel mount surface (based on an existing 2.50″ axle/brake offset)** on a lot of the write ups, but I don't know if that is with all brake units. I guess I am wondering if I need to put my brakes on to see if I have that 2.50 brake offset to begin with.
I will be using Z51 with the parking brake assembly.
Thanks,
Dan
Old 10-14-2016, 06:35 PM
Originally Posted by Dan65SS View Post
Jay-
Thanks,
Dan
Dan,
First off, thank you for your purchase.
The brake package will not affect axle length in any way.
As for the axles...
Best way to determine your axle length is to know your pinion center to outside of Big Ford End measurement for both passenger and driver side. Once that is known just let me know and I will confirm your particular applications axle lengths.
In addition to the above, I will need to know what differential you are running and if your Big Ford Ends are on a GM 12 bolt, Ford 9, or?
PM me your email address if you prefer and I will get you over an order form which then can be used to document the above requested info and sent over to me
Jay
Old 10-15-2016, 09:01 AM
Thanks for the quick reply Jay. I have sent over a PM to you with my contact details.
It is a Strange 9 inch Ford narrowed 2" a side for my 65 Chevelle. It has the pro-iron 3.90 center section in it with 35 spline setup. Big Ford bearings.
Old 02-09-2017, 07:47 PM
Advantages:
Base Kit Includes:
• (1) Install Kit
• (2) Hub Spacers
Add Axles - $400.00
Have interest?
Have questions?
Need more info?
In Stock!
Old 02-09-2017, 08:45 PM
SlowProgress's Avatar
Nice engineering! These kits get better looking all the time.
