Old 09-09-2024, 04:37 AM
andrewb70's Avatar
Instagram @dr__efi
I offer remote Holley EFI tuning.
I deliver what EFI promises.
Please get in touch if I can be of service.
My YouTube Channel
The Following 3 Users Say Thank You to andrewb70 For This Useful Post:
camcojb (09-09-2024), dhutton (09-09-2024), srode1 (09-09-2024)
  #52
Old 09-09-2024, 06:55 PM
That's moving damn quick.
  #53
Old 10-26-2024, 06:51 PM
andrewb70's Avatar
Little action from last Thursday.
We were making consistent 10.9x passes at 124.x MPH. Sixty foot times were in the 1.5x range. This was done with over 100 pounds of subwoofers and a spare tire in the trunk.
Andrew
Instagram @dr__efi
My YouTube Channel
The Following 2 Users Say Thank You to andrewb70 For This Useful Post:
camcojb (10-26-2024), will69camaro (10-27-2024)
  #54
Old 12-10-2024, 12:05 PM
andrewb70's Avatar
Here is a cool product that you guys might be interested in:
https://www.crossmembers.com/product...n-gf-mut-8hp70
I will be using it to mock up the 8HP70 in my Cougar, along with their Godzilla mock-up block.
​​​​​​​Andrew
Instagram @dr__efi
My YouTube Channel
The Following User Says Thank You to andrewb70 For This Useful Post:
camcojb (12-10-2024)
  #55
Old 12-14-2024, 10:10 AM
ScotI ScotI is offline
​​​​​​​Andrew
Those things are great for easier swap prep + validations.
The Following 2 Users Say Thank You to ScotI For This Useful Post:
andrewb70 (12-28-2024), camcojb (12-14-2024)
  #56
Old 04-29-2025, 08:20 PM
andrewb70's Avatar
This is one of my customers cars:
https://youtube.com/shorts/vUFEIJCOSsY
Andrew
Instagram @dr__efi
My YouTube Channel
camcojb (04-29-2025), will69camaro (05-02-2025)
  #57
Old 04-30-2025, 10:52 AM
Strictly Attitude Strictly Attitude is offline
I have been contemplating one of these in my 72 Chevelle I have a fueltech ft 550 lite and they offer an option to tune the trans. I need to figure out a adapter plate/converter for it to mount to my Gen 1 but just started drinking that cool aid.
The Following 2 Users Say Thank You to Strictly Attitude For This Useful Post:
andrewb70 (04-30-2025), camcojb (04-30-2025)
  #58
Old 04-30-2025, 11:05 AM
andrewb70's Avatar
I don't know anything about Fueltech or their 8HP controls, but Domiworks offer a Gen 1 SBC adapter.
Andrew
Instagram @dr__efi
My YouTube Channel
  #59
Old 06-30-2025, 08:30 PM
andrewb70's Avatar
I am working on my own 8HP70 swap into my 67 Cougar. I was using the 5th gen Camaro starter. Well, that starter has a unique nose on it and it does not work well with the Domiworks adapter. I recall having a similar clearance issue when I used that starter with a stock T56 bellhousing. Instead of butchering the adapter (more than I already did) I ordered this truck starter. It has a different nose, but still have the connector for the solenoid wire.
You can see where I have already clearanced the adapter, but had I used this starter from the beginning, that would not have been necessary.
The other difference with this starter is that it does not have provisions for the heat shield, like the one that is used on the 5th gen Camaro starter. I don't think this will present any issues.
This shows how much the bellhousing has to be notched in order to clear the nose of the starter. I could have done a slightly smaller notch, but I didn't want to keep messing with it.
I plan to 3D scan that area and have a small cover designed and 3D printed. The engine swap party is a little over 2 weeks away.
Andrew
Instagram @dr__efi
My YouTube Channel
The Following 4 Users Say Thank You to andrewb70 For This Useful Post:
Avgasman (07-09-2025), camcojb (06-30-2025), clill (07-07-2025), will69camaro (07-07-2025)
  #60
Old 07-24-2025, 08:20 PM
andrewb70's Avatar
The ZF8hp70 transmission fits better in my Cougar than the T56. I was able to raise the back of the engine about an extra inch, which actually improved the relative angle of the engine to the rockers.
This is the view on the driver's side.
and the view on the passenger side.
I used an 8HP70 mount from Holley and even recycled the transmission mount from my 89 Suburban project. I also made a new crossmember by starting with a Chris Alston Chassisworks Mustang crossmember kit. The new crossmember turned out pretty good, except when we went to install the exhaust, it hit the crossmember. :��:
I've had these little plastic bellhousing block off plates in my tool box for 15 years and I finally have a chance to use them. This one seals off the driver's side of the bellhousing.
This side loops around the started nose and seals off the passenger side opening.
I ordered a small Earl's cooler to use for the transmission and we found a good place for it on the side of the hood latch support.
My buddy Brian took this shot after we got the hood back on it.
Saturday afternoon FedEx delivered the blower belt and a few minutes later....
Tom handled the transmission fluid fill procedure while Brian shifted through the gears, which is required to fully fill these transmissions.
Yesterday I ordered a dual CV driveshaft from The Driveshaft Shop. In the meantime I need to permanently wire the TurboLamik and figure out a way to mount the BMW shifter. Ideally I would make a console, but there isn't time to do that before LS Fest.
Andrew
Instagram @dr__efi
My YouTube Channel
camcojb (07-24-2025)
