Old 10-23-2023, 09:01 AM
andrewb70's Avatar
Default Is anyone interested in the ZF 8HP transmissions?
In the last couple of years I have been reading up on various modern transmissions swaps, like the dual clutch ZF transmissions as well as the ZF 8HP70/90 range.
Is anyone interested in the 8HP swap?
After LS Fest my buddies Tom and Brian drank the ZF 8HP KoolAid with me. Tom found a smoking deal on 3 take out 8HP70 transmission and he is starting to dig into them in preparation for doing the needed modifications to use the TurboLamik TCU.
These transmissions are simultaneously complex yet simple. Here is the main case after the valve body has been removed.
This is the valve body with a total of 9 solenoids.
This is the part that needs to be modified.
The shiny plate is the OEM TCU cover. That cover gets cut off and a PCB board gets soldered in place that allows the use of an externally mounted TCU.
I would be interested in hearing from people that are interested in this swap, especially with Holley EFI.
Andrew
Instagram @dr__efi
I offer remote Holley EFI tuning.
I deliver what EFI promises.
Please get in touch if I can be of service.
My YouTube Channel
The Following 2 Users Say Thank You to andrewb70 For This Useful Post:
fleetus macmullitz (10-23-2023), srode1 (11-03-2023)
