Old 08-04-2019, 06:22 PM
Stielow's Avatar
Stielow Stielow is offline
Final parts
Needs to be inside an 18 inch wheel
Stielow Engineering
Old 08-04-2019, 06:25 PM
Stielow's Avatar
The hub is Kore 3.
Stielow Engineering
Old 08-04-2019, 07:03 PM
MtotheIKEo MtotheIKEo is offline
Nice upgrade! Did you get lucky with the rotor and caliper offset matching the original offset? Or was there some spacers/milling to make it work?
Old 08-05-2019, 08:54 AM
Stielow's Avatar
No I had to use CCP spindles that have a nice boss to build a adaptor off of.
Stielow Engineering
Old 08-04-2019, 10:25 PM
jeff71 jeff71 is offline
Stock spindle? I'm surprised those Detroit Steel wheels required so little balance weight.
Old 08-05-2019, 08:56 AM
Stielow's Avatar
No a CCP spindle with a drop built in
Stielow Engineering
Old 08-06-2019, 09:18 AM
Ketzer's Avatar
Ketzer Ketzer is offline
I have read mixed reviews on the CPP stuff in general, ie quality issues. Glad to hear a real world use ! It's really tough trying to sort through reviews and figure out whos giving honest opinions.
Jeff-
Old 08-06-2019, 12:29 PM
ScotI ScotI is offline
Jeff-
Honestly.... They (the peoples opinions of CPP) probably all are. CPP is hit & miss. Some stuff is good as is. Some stuff not so much. The follow-up when you (the little guy/John Q. Public) do have an issue leaves you wondering how they remain in business.
Old 08-12-2019, 07:17 AM
Stielow's Avatar
I added 2018 Tahoe brake booster and master. I cut the brake booster brackets off the 1978 Blazer booster. The amazing thing is the rivet pattern matched the 2018 Tahoe booster. I changed the angle and it bolted up. I had to rework the brake booster rods but over all fairly straight forward.
Mark
Stielow Engineering
Old 08-12-2019, 08:07 AM
Mark
Curious.... Was this to simply keep the paired components together or is there some specific benefit to using the 2018 Tahoe booster vs. a 78 version?
