Old 10-15-2010, 06:56 PM
awr68's Avatar
awr68 awr68 is offline
I wanted some street and track wheels and I also needed a 19 inch rear wheel for the Goodyear tires. The rear is a 325/30R19.
Mark
Ahhhhhh Ha!
Tony
'68 Camaro
Old 10-16-2010, 06:40 AM
Bow Tie 67's Avatar
Bow Tie 67 Bow Tie 67 is offline
Mark did you happen to weigh any of your wheel / tire assemblies?
Matt
Project: " Chain Reaction "
A.K.A. " BIG " by wife, biatch in garage.
1969 RS Camaro, L92 T56, Chassisworks sub, Quadra-Link, Bear, Ford 9".
Old 10-16-2010, 08:33 PM
akrapovic's Avatar
akrapovic akrapovic is offline
What clutch/flywheel are you running Mark?
Old 10-17-2010, 05:43 AM
Stielow's Avatar
Stielow Stielow is offline
No I did not weigh any assemblies. But subjectively the Goodyears are a little heavier than the KDWs.
Mark
Old 10-17-2010, 05:53 AM
Stielow's Avatar
Because we used a Callies 6 bolt crank I needed a Lingenfelter steel flywheel to adapt from the LS7 style crank to a LS9 clutch.
Old 10-17-2010, 06:31 AM
akrapovic's Avatar
I have driven a ZR1 so i know its manners are excellent, how has it held up to the extra hp?
Old 10-17-2010, 08:11 AM
Stielow's Avatar
No isses so far but I would not want to do 200 1/4 passes on it. I could smell a little cluch at the drag strip because I have to feather the launch and the 1-2 shift to keep from breaking the tires loose.
For what I use the car for it is perfect. Feels great no chatter light efforts. The Lingenfelter flywheel is the stock ZF flywheel for an LS9 except drilled for 6 bolt crank and lightened. Katech has an aluminum one but I went for the low inertia steel one.
Mark
Old 10-17-2010, 03:21 PM
akrapovic's Avatar
Thanks for the info Mark.
Old 10-17-2010, 07:02 PM
phillym5 phillym5 is offline
Mark
Dragstrip??
What did she run/ trap?
Old 10-18-2010, 05:49 AM
Scorpner Scorpner is offline
Wow, great build thread and incredible Camaro.
'85 F-41
'86 Camaro
