Old 12-02-2009, 12:18 AM
73CPCAMARO's Avatar
73CPCAMARO 73CPCAMARO is offline
Default 1973 Camaro - Autocross / Street Car project
Hello Lateral-g gang. My name is Brian Hobaugh and I am in the process of building an all out autocross 2nd gen Camaro that will also be able to be driven on the street. I have autocrossed for 24 years in Nor Cal, mostly in a 1965 Corvette that is on the Lateral-g home page. My father, Steve, and I have teamed up ever since I could drive at 16. He started autocrossing in a 74 Camaro and then a 72 Z28. In 1984 he purchased the 1965 Corvette we have been running ever since. For many years we have wanted to build a nationally competitive CP Camaro for SCCA Solo II. I finally decided not too long ago to go for it and build my dream car. I purchased the starter car from Mary Pozzi and have been going to town on it hard lately. Hope to have it completed and running by summer 2010.
Maier Racing and Mike Maier is building the chassis. Maier racing is know for its long history of Mustang fiberglass and suspension parts. Mike is amazing talented fabricator and driver (multi national champion autocross in CP) and has expanded his projects to Chevrolet Camaro's and Corvettes suspension and cage work. Almost all the suspension will be custom made pieces to obtain optimal geometry. With the help of multi national autocross champion Frank Stagnaro and my father, we hope to complete a Camaro that will look good and handle even better. Because of the rules in C Prepared, we have to keep certain structural parts in the car that would be nice to completely remove or change, such as, the rear frame rails and change out the stock subframe. The car must way 3100 lbs when we are done. Our goal is to have to add a few hundred pounds in specific areas of the car for optimum balance.
Short list of goodies going on the car:
600 HP LS3
4spd G-Force Transmission with Long linkage
9" Alum housing 3rd member and full floater rear end
Custom 3 link rear suspension
JRI Coil Overs
Wilwood Brakes
Tilton pedals
Woodward Steering column
18" x 12" rear and 17" x 12" front CCW wheels
Fiberglass front end parts and deck lid and bumpers
Maier Racing custom cage and suspension.
www.maierracing.com
I will post progress photos as we go. Here is a drawing I completed to show what the final product should look like.
Here is what we started with.
After we got the car home from Mary's, we took it all apart.
After we removed all the bolt on items, we started cutting away.
Brian Hobaugh
1965 Corvette
1973 Camaro
Old 12-02-2009, 12:30 AM
73CPCAMARO's Avatar
After the sheet metal was cut away, the cage and rear suspension structure gets built by Mike Maier of Maier Racing
The cage is tucked up as tight as possible to the body.
Old 12-02-2009, 01:58 AM
Looks good!! Whats next?
63 Z06
Old 12-02-2009, 07:26 AM
73CPCAMARO's Avatar
Here are a few more shots showing the progress of the rear cage and rear suspension and 3-link set up.
Since the rails can not be removed, only portions for clearance issues, the remaining rail is gusseted to the cage structure and capped.
Old 12-02-2009, 07:56 AM
73CPCAMARO's Avatar
Here are some shots showing Maier Racing joining the cage to the body on the rockers and A and B -pillars.
Old 12-02-2009, 08:18 AM
KPC67's Avatar
KPC67 KPC67 is offline
Hi Brian,
thanks for showing us your car, this thing is going to be awesome!
Kevin Carter
Old 01-26-2010, 10:21 AM
ZVT's Avatar
ZVT ZVT is offline
Default Rendering
Send me an email on specs I can clean up my rendering for you wont cost much to do.
Love the project !!!
ZVTDESIGNS-AUTOMOTIVE ARTIST AND VEHICLE DESIGN
[SIGPIC]https://lateral-g.net/forums/image.php4?type=sigpic&userid=4368&dateline=121287 1168[/SIGPIC]
RENDERING GALLERY!!
Old 01-26-2010, 11:45 AM
73CPCAMARO's Avatar
PM sent
Brian Hobaugh
1965 Corvette
1973 Camaro
2003 Z06
