Old 07-15-2011, 07:23 AM
MaxHarvard's Avatar
Originally Posted by z4me69 View Post
Love the intake but from what I'm hearing good luck getting it to fit without a really tall hood in a camaro
Are you saying it won't fit under a cowl hood?
Old 07-15-2011, 07:47 AM
MaxHarvard's Avatar
Just got word from the folks at holley that it might be a tight fit, but it certainly isn't a "no-go" on this intake.
I guess we'll see how it goes when I finally get the engine and subframe all mocked up.
Old 07-15-2011, 07:58 AM
1HTBRRD's Avatar
1HTBRRD 1HTBRRD is offline
With a cowl hood you should probably be fine, I'm running an LS with a truck intake (much taller than LS1 or LS6) and I have a stock hood on a 69 Firebird....but I only have about 3/8 of an inch clearance. If you want I can measure the height of my intake and you could compare it to your holley.
Build looks awesome so far.
-John
1962 Nova, LS1/ T56, DSE Mini tubs and subframe connectors, Church Boys 4 link, Viking coil overs, C6 brakes
Old 07-15-2011, 09:28 AM
MaxHarvard's Avatar
From Holley
I think the intake is 12.32 inches tall from the top of the lifter valley cover flange on the engine block
Old 07-15-2011, 12:52 PM
Roberts68 Roberts68 is offline
Max,
That Aluminum hood, is it stamped just like an OEM? I ask because some of the composite hoods offer more space on the underside and don't have all the truss work that incorporated the factory Cowl to Aircleaner seal etc...
I think Scott runs one that is virtually open on the underside. That may save a bunch of space, and perhaps you could consult with AMD or whoever made the Aluminum hood to see if it can be relieved like that. I know the Aluminum hoods are a bit thicker material than the steel. Maybe it would lend itself well to customizing?
Old 07-17-2011, 11:31 AM
1HTBRRD's Avatar
Default Intake Height
I measured the stock truck intake on my car and it was right at 10 inches tall. You should be fine with a 3 inch cowl hood and maybe even a 2 inch cowl hood.....good luck
Old 07-18-2011, 11:58 AM
MaxHarvard's Avatar
Thanks for the info!!
Update from Roger at SpeedTech.
Yet another teaser!!
Old 07-18-2011, 12:49 PM
68400BIRD 68400BIRD is offline
That's a work of art.
Are you going to Car Craft this weekend?
Old 07-18-2011, 12:52 PM
MaxHarvard's Avatar
Yep!
I gots me a golf cart this year too. Where will you be? What will you be driving? I'll stop by and say hi
Old 07-18-2011, 07:19 PM
Originally Posted by MaxHarvard View Post
Yep!
Not sure where I will be at yet. But, I plan on going all three days. I do not have a car ready yet so I will be riding along with a friend in one of his cars. I'll pm you my number.
