The Dynacorn parts either come coated with their weld-thru or the standard new part black (probably crappy - primer). Where I was going to weld or had ground, I either used weld-thru primer or in some cases used epoxy primer.
Could I have coated it more uniformly and thoroughly, probably yes........ Much of the framerails gets welded on to install the DSE stuff and what I had sprayed on the inside of the rails was burning back off in those areas. I may coat the inside of them with
http://www.amazon.com/Transtar-4423-.../dp/B00H2W3YZW
We've used it with some success in the past. I would do this once it is on the rotisserie so that I can spray it from multiple angles etc..
