Old 04-11-2015, 12:13 AM
2L8IWON 2L8IWON is offline
I was poking around last December looking of an "Economical" one piece wheel that would fit over a 394 mm ZR-1.
I saw Forgestars on a few cars and was checking them out. I called for info and I happen to call on the Black Friday sale. The normal price is still not bad but you get what you pay for. Finspeeds and Forgelines are works of art and these are OK for track wheels.
If I sell off enough used parts I will get a set of USA made mono blocks.
Mark
Thanks Mark, appreciate the time!
- Jesse
Old 04-12-2015, 11:55 AM
LXSS350 LXSS350 is offline
I did 18 x 10 with a 20 mm offset on the front and the caliper has about 5 mm clearance toward the spoke side. It has about 4 mm clearance to the barrel. Not sure you can increase offset and still have them clear the ZR-1 calipers.
Thanks Mark I ordered a set for track wheels. With only 5mm I am glad I didn't just take others advice. Even Forgestar said standard fitment for ZR1 brakes are 18x10 +30 offset and 18x12 +50 offset which would hit the calipers.
Cheers
Colin
Old 04-13-2015, 06:55 AM
aggie91's Avatar
aggie91 aggie91 is offline
thanks for the updates Mark. Your explanations of why you make the changes/modifications are great. It gives us insight to your way of thinking that can benefit all of us.
The wheels look great with the yellow on the car!
Karl
1965 Chevrolet C10
1982 Chevrolet C10 - My son's Truck - Sunburn
Old 04-13-2015, 08:41 AM
clill's Avatar
clill clill is offline
I think that POS needs a set of polished wheels.
Old 04-13-2015, 08:32 PM
Sieg's Avatar
Sieg Sieg is offline
Intro 22's FTW
Old 04-18-2015, 06:44 AM
Stielow's Avatar
Stielow Stielow is offline
Old 04-18-2015, 07:01 AM
Stielow's Avatar
The new oil to oil diff cooler on in the center section.
The Camaro ZL-1 diff cooler
My axle ends that you can now buy from Detroit Speed
Mark
Old 04-18-2015, 07:07 AM
tubbed69's Avatar
tubbed69 tubbed69 is offline
Just as always Mark,very impressive work to a already well built car
Old 04-18-2015, 05:17 PM
Are you planning a door like a gas door for access to the oil fill? Looking good as always, Mark.
Old 04-19-2015, 05:07 AM
Roberts68 Roberts68 is offline
I'm not sure if this is the one and only access to it, or if you had seen it a few pages back.
Matt made the passenger inner wheel house two piece on JA to make it easy to get the dry sump tank hidden in the cowl area.
