Old 02-28-2021, 07:23 AM
RdHuggr68 RdHuggr68 is offline
I run a master battery disconnect in the trunks next to the battery. I’ve never fused the large power cable from the battery to the front of the car. In practice it would be a good idea. Not sure of the best way to do it.
Mark, do you use a remote solenoid in the trunk? Also what route did you use to run your positive cable to the front?
The Following User Says Thank You to RdHuggr68 For This Useful Post:
syborg tt (03-08-2021)
  #752
Old 02-28-2021, 12:22 PM
70w30 70w30 is offline
Do you know what the airflow/cfm rating on that CTS-V fan might be?
Looking at laying down a rad in the nose so a lot of pull would be beneficial. Maybe even make a little downforce...
Old 02-28-2021, 12:43 PM
andrewb70's Avatar
GM rates their fans in watts, and the fan that Mark is using is 850watts. It wouldn't surprise me if it was over 6000cfm.
Andrew
Instagram @dr__efi
I offer remote Holley EFI tuning.
I deliver what EFI promises.
Please get in touch if I can be of service.
My YouTube Channel
The Following User Says Thank You to andrewb70 For This Useful Post:
shume (03-01-2021)
  #754
Old 03-02-2021, 07:21 PM
Stielow's Avatar
Stielow Stielow is offline
My maiden voyage to my buddies house Brad. It is alway good to go to somebody’s house that you know has tools. First drive was 75 miles. I had one loose bolt that allowed the splines sway bar arm to fall off.
Fixed it and drove it back to Sled Alley. Off the the chassis dyno this week.
Stielow Engineering
The Following 10 Users Say Thank You to Stielow For This Useful Post:
cpd004 (03-03-2021), EVIL SS (03-03-2021), fleet (03-02-2021), kwhizz (03-03-2021), redfire69 (03-03-2021), Spiffav8 (03-09-2021), syborg tt (03-08-2021), waynieZ (03-02-2021), will69camaro (03-02-2021), WILWAXU (03-02-2021)
  #755
Old 03-02-2021, 07:28 PM
randy randy is offline
Rubber mallet to push the bar back in the splines huh? Been there done that lol
The Following User Says Thank You to randy For This Useful Post:
  #756
Old 03-02-2021, 07:46 PM
PTAddict PTAddict is offline
Awesome cars and awesome people. That's what this hobby is all about.
Latest car: https://lateral-g.net/members/borduin/
EFI Tuner for: http://www.modernclassicsauto.com
Old 03-03-2021, 03:43 AM
Stielow's Avatar
This is my “Race Track” screen. One of the biggest reasons I did Dakota Digital is so I could get this set up. Full analog gauges plus a DIC (Drivers Information Center) that shows - Tire pressures, Engine Oil Temp, Diff Temp and Trans Temp. The only think I don’t have is fuel pressure on the dash. It is on the CAN bus and I thought it would display. I can data log it and look at it later which is sometime better. Something else to sort out.
Stielow Engineering
The Following 9 Users Say Thank You to Stielow For This Useful Post:
130fe (03-09-2021), 68454RS (03-03-2021), 89 RS (04-18-2021), camcojb (03-03-2021), dhutton (03-03-2021), redfire69 (03-03-2021), Rodknock (03-03-2021), syborg tt (03-08-2021), WILWAXU (03-03-2021)
  #758
Old 03-03-2021, 06:00 AM
Stielow's Avatar
To pop the deck lid I use a Year One trunk popper. I have tried other ones and they don’t have enough power to do it.
On the main positive battery cable it runs inside the car. The battery is in the trunk and the cable runs down the rear wheel tub then in the wiring trough under the passenger door sill. Then across the toe pan to a pass through.
Mark
Stielow Engineering
The Following 4 Users Say Thank You to Stielow For This Useful Post:
65 Drop Top (03-15-2021), RdHuggr68 (03-03-2021), redfire69 (02-04-2022), syborg tt (03-08-2021)
  #759
Old 03-03-2021, 09:04 AM
Mark, I didn't explain myself on the solenoid. I meant a remote starter solenoid in the trunk so the pos. cable is only hot during startup. BTW your car looks great, can't wait to see the dyno specs!!
Old 03-03-2021, 10:27 AM
camcojb camcojb is online now
Also why I went with Dakota Digital, great looking stuff and the ability to do way more than standard gauges.
Frankenstine (03-03-2021)
