Old 11-23-2014, 08:37 AM
coolwelder62's Avatar
From the work I've seen from you it doesn't surprise me at all.
Thanks,Wayne.
Old 12-05-2014, 05:54 PM
Sonar Chief's Avatar
Cool Update 12/5
A good day in the garage, it was in the 50's and I had to get something done on the Camaro .... so I finished removal of the spring perches, mocked up the RT weld-on lower brackets, fabbed some 3/16 strap to simulate the shock height at 14.5", and fitted Scott's fix to my tranny mount issue.
Need to recheck the angle of the lower brackets and the side2side center and tack the brackets and tack the tranny adapter in place ... then take it to work and use the BIG welder again.
Got the perch off and ..... YES that is BONDO! WTF?
Mock straps and set width.
Ride Tech setup is sweet!
Clamped on Scott's adapter to the crossbrace.
View from bottom ... Scott's welds are beautiful!
That's why I went w weld on brackets .... an extra inch per side!
Was gonna get the subframe connectors in, but a slight engineering fault (my bad) ... the side plates I welded on are too long and I can't get the connector up in the car and slide past the cross member brace. So I have to pull the front end out and then put the connectors in and then slide the subframe back and line it up w the connectors .....
Thanks for looking ....
Old 12-05-2014, 10:38 PM
Don't ya just love hot rodding!! LOL
Looks good!!
When I'm doing this kind of stuff -- I make "lists".... and then I just cross 'em off as I get 'er done... It's less daunting when you see the list of stuff being crossed off.
Old 12-06-2014, 10:37 AM
Rod P's Avatar
Rod P Rod P is offline
the bolt on axle bracket has also been moved over that extra inch also...I was just mentioning it so if someone wants the bolt on kit they wont think there sacrificing any clearance...sorry for the thread jack
Rod Prouty
My websiteAuto-cross 101
Bangshift Stories
Old 12-06-2014, 01:03 PM
Thumbs up
Looks good!!
Thanks Greg ... if I started a list the light at the end of the tunnel would extinguish!!!
Rod, no jack at all, I encourage comments! If you look at post #761 with the bolt on brackets, there is no other way the lower bars can get mounted, they have to be inline w the perches, yes? Unless I'm really messed up how can you gain extra clearance when the perches are 42" c2c?
Anyway, thanks for looking .....
Old 12-06-2014, 06:29 PM
jlwdvm jlwdvm is offline
The bolt-on perches are offset to the center on each side...that is where you get the 1" extra clearance on each side. They are offset to the center just like both ends of the bar are offset to the center. I have the bolt-on bar mounts on my 69 firebird. I also spent a lot of time squaring up the front and rear wheel mounting surfaces, adjusting the front sub frame, moving the rear side-to-side, etc prior to welding on my upper perches....probably too much time!
http://www.pro-touring.com/threads/1...ar-build/page4
All the measuring fun started at #75
Old 12-06-2014, 06:55 PM
Rod P's Avatar
Yes like jlwdvm said, we offset the mounting bracket bosses towards the center of the car on the mounting plate......I guess I should stop saying we I leave RideTech in January
Rod Prouty
Bangshift Stories
Old 12-06-2014, 10:08 PM
Thumbs up Thanks!
Joe .... that's a nice Firebird, I had to go back and look at some of the pixs I took of the 4 bar and see the offset of the lower brackets ... duhhhh! I had them on the wrong sides (my bad!), oh well, I think the weld on brackets look cleaner! Hey, its only metal!
I will take your Firebird posts for reference to getting all things square Front2Back, wish I had a lift thou!!!!
Rod ... thanks for the clarification, don't want to be doing this twice
Old 12-07-2014, 09:01 AM
Rod P's Avatar
it happens....have any build questions just give me a yell...even thou I'm leaving RideTech I can still help you with tech
now
Rod Prouty
Bangshift Stories
Old 12-07-2014, 09:30 AM
Cool
now
Rod ... appreciate it, may take you up on that!
You know what would be great ... having the instructions updated!!
If RT needs pixs I have plenty that could replace the rusty Camaro that is in the instructions.
Michael
