Old 01-05-2009, 11:12 AM
aussiebj's Avatar
aussiebj aussiebj is offline
Black on black with dark shadow graphics
Old 05-13-2009, 01:01 PM
70rs's Avatar
70rs 70rs is offline
I just read your build thread from the start. Nice work and great progress.
Is there any updates? It's going to be a sweet car when it's done.
Old 06-07-2009, 06:27 PM
aussiebj's Avatar
Ok so i finally finished up some other projects and now i can focus my attention back on to the stang...
decided to redo the engine set up so i moved the engine back 8 inches which puts it behind the rack ..but in doing so i now have to rework the front crossmember..i also lowered the engine so it now sits lower in the frame ..mocked up some hedders and am onto fabricating the motor mounts and tranny mount...removed the brake booster setup and i am going with a hydra boost setup....update pics....
Old 06-13-2009, 07:34 PM
aussiebj's Avatar
ok motor is in its final position ....finished up tranny mount...removed the drive train... ..mocked up steering as well as installed new Flaming River tilt steering column.....started motor tear down for painting and checking...its a nice piece 030 thou over 460 with forged pistons never been run since rebuild...anyway here are the pics....
New drivers motor mount and steering
Pass eng mount and headers
Steering top view
Tranny mount
HMMM new parts
Top view pass header
Old 06-14-2009, 07:07 PM
aussiebj's Avatar
ok i removed the engine and tranny again this weekend ...Broke the motor down for a regasket and general go over ..removed the rack and steering column..started to mock up a firewall..here are the pics...
Everything removed
nice pistons
Firewall mock up
Firewall rough in metal
Old 06-22-2009, 02:04 PM
aussiebj's Avatar
Engine is 95% back together and detailed...did some finish welding/clean up of the engine bay ...cut and welded the firewall in ....reinstalled the fenders and new radiator support to mock up the inner fenders......heres the pics
460 030 over ....HS roller rockers with a big hyd flat tap cam..
Firewall cut and welded in
Inner fender mock up
Old 06-22-2009, 07:47 PM
Car's looking good.
Old 06-22-2009, 08:44 PM
Kendall Burleson Kendall Burleson is offline
It look like it coming alone good!
Old 06-24-2009, 02:44 PM
aussiebj's Avatar
Worked on the floor supports today 1x2 tube ..the center bar between the rail (where the d/shaft goes) will be cut out and a reverse of the tranny crossmember will take its place once the majority of the floor is made.....
Old 06-24-2009, 02:47 PM
aussiebj's Avatar
Finished up some more of the floor framework ....installed the rea floor pans ..started mock up of the front pans but i wont install them permently until the motor and tranny go back in...
Need to trim down the tranny tunnel as well..
