Old 10-12-2008, 05:42 PM
aussiebj's Avatar
aussiebj aussiebj is offline
Default 69 FASTBACK (project 57)
Well i am back and building a new car no its not a 57 chevy as the title might lead you to belive but a 69 mustang fast back..plans call for a 460 bb with a C6 tranny, mini tubbed with 315`s under the rear, with a triangulated late model rear end, disc brakes all round , complete front end removed and a pro touring mustang type front end installed sitting low and mean....I post pics as soon as its in my garage just finishing up a 69 tubbed nova with a 650hp on motor small block here is a pic of the nova
....anyway here are some links to my other builds project Swiss Cheese and Bad Mav just as a refresher......
http://www.pro-touring.com/forum/sho...t=swiss+cheese
http://www.pro-touring.com/forum/showthread.php?t=26809
Old 10-12-2008, 05:43 PM
aussiebj's Avatar
Ok i got around to adding some pics...does anyone have any pics of a sub frame removed from a mustang and a pro street/touring front end installed or have any recomendations this car will be low and mean maybe ill just build my own ..anyway here are the start up pics..
Old 10-12-2008, 05:44 PM
aussiebj's Avatar
Here it is in the garage next step is to remove the fronnt subframe and rear end set it at a 5 inch ride height and start fabricating...
aussiebj's Avatar
here is the mock up of the wheels i will be using ..17 x 10.5 new style bullit`s with 315x 35 x 17`s
Old 10-12-2008, 05:46 PM
aussiebj's Avatar
This weekends progress consisted of removing the rear and leaf springs ,removing the old front end frame rails and all ,started to clean up the body ill be repairing the drivers quater and replacing the passengers. I thought i could get away without mini tubbing the rear but 315`s are big tires so a mild mini tub will have to be done .....here are some pics.
[[/IMG]
Hey looks killer with 315`s on the front
Set at 7 inches to the ground this will probably be the ride height...
hung the front fenders on to see if the 315`s would clear...
Old 10-13-2008, 04:50 AM
cees67's Avatar
cees67 cees67 is offline
lookin good!
Old 10-13-2008, 10:23 PM
rjardy rjardy is offline
Looks great. I see you figured out how to "remove" the sub-frame on a mustang!
Rob
Old 10-19-2008, 05:51 PM
aussiebj's Avatar
Ok here is this weekends update 10/19 removed the rest of the front frame rails and found 30yrs of rust and a bad front end repair, so while i was in the metal removing mood i removed the front torque boxes and both floor pans as they were replaced before and not done well ,looks like i will be building a full frame for this car..here are some pics
30 yrs of rust
new frame arrives
QA1 coil overs nice
new brakes
Old 10-19-2008, 05:52 PM
aussiebj's Avatar
Frame under car crossmember will be at 5 to 6 inches off the ground
removed the old wiring as well
no rust in these floors
Old 10-19-2008, 08:09 PM
With the pans and the clip cut off, did you brace the car anywhere?
