Old 05-02-2012, 01:02 PM
OLDFLM's Avatar
OLDFLM OLDFLM is offline
Flux capacitor?
1.21 jigawatts!
Ty Ingle, USAF Retired
FREEDOMBIRD
Old 05-02-2012, 06:17 PM
FETorino's Avatar
FETorino FETorino is offline
Question Details
The ‘67 is an evolution of Red Devil: A little more power,little less weight a little more grip… I did a ’67 because they are a bit smaller and lighter than a ’69.
No major changes:
All DSE Chassis
Thomson Engine
D&D Performance Trans
Brembo Brakes
Ricks Fuel Tank
SED ABS Brakes and Carbon Fiber Hood
Etc…..
Mark
Where will you save the weight and where will you gain the grip?
I'l guess a lighter housing for your straight axle in back. Hollow axles did you run those before?
Lighter break package.
New shock package save weight and improved dampening = better grip.
Maybe a little less weight up front with the radiator/ cooler/ core support package. It looks like the radiator package you have has all the heat exchangers integrated into one unit?
I didn't see you mention transmission. Something track specific in magnesium?
Slightly bigger front and smaller rear tires with a cambered rear?
Lots of guessing with no basis on my part. Just proding you for some real details.
Rob in SoCal
Old 05-03-2012, 07:41 AM
GRob GRob is offline
I'd like to see some titanium bits start working themselves into the build. Bolts, nuts, exhaust piping, headers. All that stuff is big money but when you are shaving ounces . . .
Old 05-03-2012, 09:34 AM
clill's Avatar
clill clill is offline
You aren't going to see a bunch of exotic metals for weight savings. Mark does not have that kind of money. His credt card is almost maxed out with each build.
Old 05-03-2012, 09:46 AM
OLDFLM's Avatar
Didn't he use mostly stock hardware on his last couple of builds? I seem to remember him having a literal bucket load of stock nuts/bolts/J-clips etc cleaned up and coated...
FREEDOMBIRD
Old 05-03-2012, 09:54 AM
sik68's Avatar
sik68 sik68 is offline
More power & less weight, but significant enough changes to warrant the expense of building a new car vs. modifying RD...there's something in plain sight that we aren't seeing!
Steven
1968 Camaro: "TRACKDAY"
Build In Progress: https://lateral-g.net/forums/showthread.php4?t=10706
Old 05-03-2012, 10:00 AM
OLDFLM's Avatar
More power in a smaller and lighter car...
FREEDOMBIRD
Old 05-03-2012, 10:19 AM
sik68's Avatar
Yep, 67 vs 69 as he said is a lighter platform...maybe 200lbs max between the two? There is aluminum front sheetmetal for a 69 though so there may be something to offset that.
I'm also on pins and needles to see what you're doing with the tire widths...near 50/50 weight distribution with square or nearly square widths?
Oh yeah, PTM...you heard it here first!
Steven
Old 05-03-2012, 12:11 PM
preston preston is offline
Time to start moving the drivetrain and passengers backwards in the car.
Whenever I contemplate pro-tour competitive builds, I am alwasy stumped by what you can do to be better than a late model vette- They have us beat on weight distribution, IRS, unsprung weight, aero, and development. If I was building a max effort pro-tour car I think I would just give up and drop a vintage body on a C6 running chassis. Because the down side to the vette of course is you see 5 of them a day even in Seattle.
The other avenue you can pursue of course is the super lightweight approach ie street rod based design or similar. That won't work with the muscle car envelope though.
Well Stielow's builds are always interesting although with his car building experience I'd like to see him push the envelope a bit more. As he's said though the key to much of his success is being fairly conservative overall and simply applying ingenuity to the details.
Old 05-03-2012, 01:18 PM
OLDFLM's Avatar
Aluminum core supports are also available (AutoRad) as well as complete CF front clips for these cars... even 2nd Gen Pontiac Firebird/Tran Ams have CF noses, hoods, fenders and doors now!
I'd like to see Mark take advantage of ALL of the weight saving products available from out site sponsors and other vendors!
FREEDOMBIRD
