Old 05-23-2016, 02:46 PM
67RSRAG's Avatar
67RSRAG 67RSRAG is offline
Originally Posted by JakeR View Post
Its an LS7 block with a full forged rotating assembly so I can spin it nice and high in the RPM range like I wanted. It’s still 427ci displacement, naturally aspirated, and is setup to run on the 91 octane premium gasoline we have out here in California. Being naturally aspirated, it is super fun to drive and helps the reliability while keeping underhood temperatures under control.
Even though it sounds nasty my dad is very particular about all our cars being very streetable. No lightweight clutches or crazy cams. Even with those numbers the car idles through LA traffic (which I do too often) like a champ and I wouldn’t hesitate to drive it anywhere.
Hey Jake do you know the cam specs ? also what compression are you running?
Those are some pretty good numbers.
Old 05-23-2016, 04:04 PM
The radiator mods look great.
Old 05-23-2016, 05:32 PM
gnx7's Avatar
gnx7 gnx7 is offline
Love this car! The straight shot intake over the radiator on a high HP LS engine over one with a 90* bend will add an easy 20rwhp+.
We have tested this on a number of conversion cars running LSx swaps.
Old 05-24-2016, 02:43 PM
Air-bender Air-bender is offline
Default Weight
Jake,
What is the weight of the car now? How close are you to the #3,200?
Old 05-24-2016, 05:07 PM
Chad-1stGen's Avatar
Chad-1stGen Chad-1stGen is offline
Originally Posted by Air-bender View Post
Jake,
I'll let Jake answer if he wants to but it is quite a ways from the 3,200 minimum for the USCA.
Autocross and Track blog
Lots of autocross & track day videos of my car: https://www.youtube.com/user/TheDude023
Old 05-26-2016, 02:25 PM
JakeR's Avatar
JakeR JakeR is offline
Thanks! The cam specs are proprietary to the guys over at Lingenfelter. If you're interested in purchasing something I would highly recommend giving them a call, they have been very helpful. I don't remember what the compression was off the top of my head but its nothing crazy since it was built to race on 91 octane. The cam isn't crazy either. Sadly living in L.A. means this car sits in a lot of traffic when I drive it to events.
They did a lot of head work to get those numbers and the MSD intake also contributes to why the numbers are so good.
Jake Rozelle
@jakerozelle
http://jakerozelle12.wix.com/jakerozelleracing
Old 05-26-2016, 02:27 PM
JakeR's Avatar
Thanks! And like gnx7 mentioned its pretty cool how it was able to help us with our intake tube performance. Win Win!
Jake Rozelle
@jakerozelle
Old 05-26-2016, 02:33 PM
JakeR's Avatar
Jake,
Not as close as I would like! haha
With under a half tank of gas at the last SCCA event the car weighed about 3350 lbs. Not terrible but If I could drop another hundred pounds I would be happy.
At least if anyone ever wants to challenge my car's weight at an event I have nothing to worry about
The oil, trans, power steering and diff cooler along with the fire suppression bottles and the 13ish quart dry sump all make it so this car runs incredible and safely on the road course but they certainly add a lot of weight.
At least the driver doesn't weigh much...
Jake Rozelle
@jakerozelle
Old 06-25-2016, 03:14 PM
PTAddict PTAddict is offline
Jake,
Great job on the car for far, and thanks for sharing. I saw you ran a 1:58.2 lap at the Thunderhill USCA - that is flat out hauling the mail and a big tribute to both driver and car.
Based on your and Stielow's experience, I finally decided to pull the trigger on some Anvil fenders and inners. No matter what I do, my car ultimately seems to be limited by front grip, and I'm hoping 40mm more tire and less weight will be just the ticket. What backspacing did you end up with on the 18x11 front wheels? And did they rub anywhere? Trying to figure out my wheel options ... And of course I understand I still need to measure for myself
Thanks much for any info,
Latest car: https://lateral-g.net/members/borduin/
EFI Tuner for: http://www.modernclassicsauto.com
Old 06-30-2016, 09:29 PM
JakeR's Avatar
Originally Posted by PTAddict View Post
Jake,
Hey Scott thanks for the props! I love Thunderhill and can't wait to go back and am pretty pleased with that lap. We've made some more improvements and I'm hoping for a 57 next year with some luck Come by and say hi at an event sometime.
We are running 18x11s up front with 6 1/4 backspace and it is a very tight fit in and out. If we had gone a quarter inch more or less it would have been bad as right now there is just light rub on both sides of the tire.
Another little tip on the Anvil stuff is to run it on the car for a bit before doing paint/bodywork if possible as it does seem to shift and settle at first. Ours did fit pretty well though so no complaints.
Any more questions just let me know!
Jake Rozelle
@jakerozelle
