Old 06-25-2013, 10:51 PM
Track Junky's Avatar
Moroso's Accumulator is connected to the pressure side of the engine's oiling system. When the engine is running, oil pressure forces reserve oil into the accumulator and compresses the air ahead. If oil pressure should suddenly drop because of hard acceleration, severe cornering or hard braking, the air pressure immediately sends oil to the main galleries. When the danger is over and the pump is once again primed with oil, the oil pressure forces oil back into the Accumulator where it is ready for the next emergency.
Moroso has 3 types of Accumulators. There is the original Accumulator which can be used for street or track. The Heavy Duty Accumulator is designed for extreme applications and all-out competition. The Accumulator 2 is highly recommended for light-duty applications including small-displacement street performance and mild off-road vehicles. All are available in a 1.5-quart version while the Accumulator and Heavy Duty Accumulator also have a 3-quart version. The 1.5-quart version is perfect for small displacement and 4- and 6-cylinder engines while the 3-quart is for 8+ cylinder applications. Moroso Accumulators come with a manual ball valve (except Accumulator 2), unlike competing models.
Moroso Accumulators can also be used to manually pre-lube engines before starting to prevent cold-start scuffing and premature bearing wear.
Gaetano Cosentino
Old 06-25-2013, 10:53 PM
Anytime the pressure in the accumulator exceeds the oil pressure in the engine, it pushes oil into the bearings. Let's say you are humming around a corner with 60 psi and you have starvation and the pressure starts to drop, the accumulator with push oil into the engine until the pressure equalizes. Once it equalizes, the accumulator will be at full capacity again momentarily. If you were to lose all oil pressure, it would oil for 3-4 seconds. When you shut off the engine, the accumulator empties into the engine. When you start the car, oil pressure will be low until it fills the accumulator.
Old 06-25-2013, 10:56 PM
Vince@Meanstreets's Avatar
Thanks Dale. There is a sheetmetal piece that Vince fabbed up that completes the connection to the firewall. We had been using it with the lid set up and needs to be cut down a bit. I forgot to bring it home from the shop.
Funny you mentioned the holes. I didn't really notice them until you pointed them out. I'll have to see if they actually do aid in introducing air into the box.
no, the whole inner section has a separate pan...its closed off to those holes.
Can you set an accumulator up to introduce oil at a specified oil pressure? Once that oil is introduced into the system does it retrieve it back when pressures are adequate?
what ever pressure you had at shut down, there is a shrader valve on the side, maybe you can?? Never researched it.
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Thanks, got it.
Gaetano Cosentino
Old 06-25-2013, 10:59 PM
Let me know when you got time to help me install an accumulator. Anytime after June 30th and before August works for me.
Gaetano Cosentino
Old 06-25-2013, 11:06 PM
Gonna have to be in August. When is the next battle? August or September. Send me some dates.
I have been wanting to change out all of your lines too, also make an aluminum cooler mount...for a year now.
Dealer for
NEVER FORGET -11
Old 06-25-2013, 11:09 PM
Hoping to make August 3rd then Sept 15th
Gaetano Cosentino
Old 06-25-2013, 11:27 PM
Ron in SoCal's Avatar
Finally...
Ron in SoCal
69 Camaro in progress
Old 06-25-2013, 11:31 PM
That's about when you'll be ready toots
Dealer for
NEVER FORGET -11
Old 06-26-2013, 08:26 AM
intocarss's Avatar
Yes you can, here is one i installed year ago on a drag car. See the solenoid at the bottom,that opens at a certain drop in pressure..
http://masterlube.net/
