Old 12-26-2014, 05:18 PM
Build-It-Break-it's Avatar
Looks like you could grind material off the front rack mount to clear the mounting bolt.
Ahmad B
Old 12-26-2014, 05:24 PM
Sonar Chief's Avatar
Yeah I flipped it 180* it won't fit either way ... a button head 5/8 bolt might help thou!
Old 12-26-2014, 05:30 PM
Or maybe swap to an Allen head bolt? It may take awhile to tighten tho. I had the same problem on my mustang rack but I'm just going to grind the front mounting brackets where the bolts are hitting .
Ahmad B
Old 12-26-2014, 06:23 PM
grendel grendel is offline
Do none of that:
Offset rack and pinion bushings:
http://www.summitracing.com/search/p...et-bushing/yes
My garage builds, with some hack and professional love thrown in:
68 GMC C1500
Haulin more than the mail
73 Camaro
Better grow a mullet
70 K5 - 4wd turned 2wd
Project might as well...
Known as John or "JJ"
Old 12-26-2014, 06:33 PM
coolwelder62's Avatar
Michael,how about I send my new design for free on Monday. I can send you the alum. parts and you can just cut off the bent bracket drill 2 holes and your done.
Old 12-26-2014, 06:42 PM
Or way and above and beyond the call of duty: Scott does it again.
Edit: with the offset bushings I linked, it will move the rack input away from the gusset.
68 GMC C1500
73 Camaro
Old 12-26-2014, 07:28 PM
Cool
Originally Posted by grendel View Post
Do none of that:
Scott .... just have to get longer bolts for the Al standoffs?
Thanks again for willing to solve problems, I do appreciate it!
Or way and above and beyond the call of duty: Scott does it again. SCOTT DOES PROVIDE SERVICE AFTER THE SALE!
Jay .... I see what you're stepping in, use the offset bushing to the pass side instead of its intended use for lowered vehicle ( put em @ 9 o'clock instead of 6 o'clock).
I'll try the offset bushings and mod the front if I have too!
Thanks for helping guys!!!
Old 12-26-2014, 07:34 PM
Correct. There is enough threads on the rack ends to take up the offset of the rack to clear the steering input.
68 GMC C1500
73 Camaro
Old 12-26-2014, 08:08 PM
Two great fixes !
Old 12-26-2014, 08:13 PM
I'll send longer bolt's also.
