Old 08-29-2014, 06:38 AM
Swain's Avatar
Swain Swain is offline
Very nice Mark.
Jason Swain
Build Link 68 Camaro
https://lateral-g.net/forums/showthread.php4?t=16865
Old 08-29-2014, 06:42 AM
Stielow's Avatar
Stielow Stielow is offline
Default Clutch
I went with a Centerforce Clutch and D &D Performance in Wixon Mi installed a oil pump in my trans. They are offering this now. It is the same pump as the TR6060 in a Magnum box. I will use it to pump my trans fluid to the rad to cool the fluid then that fluid will go to the diff.
This a GT500 throw out bearing with a quick connect. The GT500 CSC has more travel and a smaller effective piston area so it will stroke farther.
Diff cooler
I installed the engine, trans, rear axle, drive shaft and fuel tank last weekend.
Also you can see the Bosch ABS controller in this shot in front of the engine. Late change to go to Bosch to work with the Carbon Ceramic Brakes
Old 08-29-2014, 06:55 AM
Stielow's Avatar
Old 08-29-2014, 06:58 AM
Sieg's Avatar
Sieg Sieg is offline
Progress!
Old 08-29-2014, 07:07 AM
Track Junky's Avatar
Lord!! The Insanity!! This car is going to be insane!!
Gaetano Cosentino
Old 08-29-2014, 07:59 AM
MeanMike MeanMike is offline
Interesting. I love how you use so many factory parts. How do you bleed the system?
Old 08-29-2014, 08:49 AM
bentfab's Avatar
bentfab bentfab is offline
Hey Mark,
Can you clear some room in your PM box.
Mark
Follow us on Instagram = @bentcustom
www.bentcustomandperformance.com
Old 08-29-2014, 08:53 AM
Ppd1979 Ppd1979 is offline
In the picture of the front of the trans is the fluid pump in the bottom left?
Old 08-29-2014, 09:09 AM
Stielow's Avatar
Yes the discharge for the pump is the AN fitting on the lower left. The return is on the side of the trans.
Old 08-29-2014, 10:08 AM
mitch_04 mitch_04 is offline
I hope to someday have a project and shop that are so clean I can work in shorts and sandals...well... I still work in shorts and sandals, but my feet are really dirty!
Thanks for the thread Mark, it's inspiring watching this build. Above my budget, but I love the engineering that goes along with the parts. The differential cooler, Z06 rear axle bearings...great stuff!
