Old 08-31-2014, 11:00 AM
tom091074 tom091074 is offline
I'll stay turned either way. love your builds!
Old 08-31-2014, 12:55 PM
GRob GRob is offline
Mark, as always your build is impeccable.
Will you be using Brembo's CCM-R brakes which appear to be their aftermarket carbon brake offering or will you be adopting the OEM Z-28 brakes to your application?
Old 09-02-2014, 04:34 AM
Stielow's Avatar
Stielow Stielow is offline
Originally Posted by Valve Lash View Post
Mark are you using -12 for both the feed and scavenge lines to the Peterson tank? Looking at their part numbers it's confusing because they have a -16 port for their LS7 pan adapter?
615-08-0502 -12X-12
615-08-0503 -16X-12 ???
I like using a -16 to feed the engine and a -12 to return to the tank. It maybe over kill but it adds oil volume to the system and seem directionally correct.
Mark
Old 09-02-2014, 06:19 AM
LS7 Z/28 LS7 Z/28 is offline
Mark
Thank you Mark. So you are running the larger -16 line but your aren't modifying the tank and the LS7 pan... You are reducing from -16 down to -12 at the both connections of the feed line?
Old 09-02-2014, 11:45 AM
cjfirstgen's Avatar
cjfirstgen cjfirstgen is offline
This a GT500 throw out bearing with a quick connect. The GT500 CSC has more travel and a smaller effective piston area so it will stroke farther.
Hmmm...so I will be running a Tilton 7/8" mstr cyl and was planning on running a Tilton 6000 series TOB. Would this GT500 TOB be the way to go on a T56 Magnum?
Project "Mercury Rising" '69 Camaro : https://lateral-g.net/forums/showthread.php4?t=41460
Old 09-02-2014, 12:06 PM
Stielow's Avatar
I'm running the production Corvette ZR-1 CCM brakes with Bosch ABS ECBM. We ran CCMs on Jackass and they work great, just a bit challanging on the track to keep from locking a tire when they are hot. They go up in output as they get hotter.
Mark
Old 09-02-2014, 12:07 PM
Stielow's Avatar
We have a Peterson tank with a -16 output and the oil pan is stock LS7 so it does neck down at the pan.
Mark
Old 09-02-2014, 12:11 PM
Stielow's Avatar
The OE CSC (Concentric Slave Cylinders) self-adjust as the clutch wears. The "race" stuff needs to be set and as the clutch wears the pickup point moves. Well that is how it was explaned to me by one of the guys who designed this stuff.
So far the pedal efforts for my set up feels great. I bench bled my CSC and my master cylender before I installed them so it worked right are without a bleed.
Mark
Old 09-02-2014, 12:18 PM
Mark
Thank you Mark
Old 09-02-2014, 08:20 PM
SlowProgress's Avatar
Default Clutch Choice and coolant loop
Mark when you get a chance please post up the thought process behind the Centerforce clutch over the LS9 clutch you were planning earlier.
Also, any photos of the liquid coolant loop routing would be appreciated.
Thanks for all the useful information!!
