Old 10-19-2010, 02:18 PM
70TWO NOVA's Avatar
70TWO NOVA 70TWO NOVA is offline
Originally Posted by vannatta20 View Post
Dont forget to measure your drivetrain angle. I think the tranny needs to be at -1 to -3. Do you need a poly tranny mount? My dad has an extra. Remember all the issues I had using rubbers. My stock LS1 ripped them in half. You should really change them.
yeah ive been thinking about that, as of now the angle is way too steep. Im not quite sure how to remedy it since i dont have a ton of room in the tranny tunnel to bring it up, and the only other option is to bring the engine down which would constitute cutting and altering the frame mounts to be lower.
Brian Miller
-1972 Nova
-1968 Camaro
-1967 C-10 step side 4x4
-2000 Dodge Dakota
it'll buff out........
Old 10-19-2010, 08:53 PM
70TWO NOVA's Avatar
ok fixed it, got the rear of the trans up just enough to get the 3-4 degree downward drivetrain angle. Also got the cross member all figured out too.
Brian Miller
-1972 Nova
-1968 Camaro
-2000 Dodge Dakota
Old 10-20-2010, 12:30 PM
strtlegal's Avatar
strtlegal strtlegal is offline
When you guys do take her out would like to to catch up..Some of these westside carshows are turning out to be the same ole same ole...Would like to meet up with some of you guys that have some creative thinking...
good work!
70 Nova: LS2/Tko600. Speedtech Stuff
Chuck D
Old 10-20-2010, 01:57 PM
70TWO NOVA's Avatar
good work!
Sounds like fun, I hear you about the local shows, they tend to get old after a while. I would like to check out your Nova too!
Brian Miller
-1972 Nova
-1968 Camaro
-2000 Dodge Dakota
Old 10-21-2010, 04:55 PM
70TWO NOVA's Avatar
Well I finally finished altering the transmission cross member and pulled the engine and transmission out again today. Next some finish welding to the mounts, firewall plate and then bodywork and paint on the firewall. Ill post up some update pics soon.
Brian Miller
-1972 Nova
-1968 Camaro
-2000 Dodge Dakota
Old 10-22-2010, 05:57 PM
70TWO NOVA's Avatar
Got the welding done on the motor mounts and firewall plate. Now to the fun part, bodywork....
Brian Miller
-1972 Nova
-1968 Camaro
-2000 Dodge Dakota
Old 10-25-2010, 05:40 PM
70TWO NOVA's Avatar
Brian Miller
-1972 Nova
-1968 Camaro
-2000 Dodge Dakota
Old 10-29-2010, 06:10 PM
70TWO NOVA's Avatar
popped the windshield out, just about finished the bodywork, and got the holes drilled for the A/C and heat bulkhead connector...
Brian Miller
-1972 Nova
-1968 Camaro
-2000 Dodge Dakota
Old 11-03-2010, 02:29 PM
70TWO NOVA's Avatar
Primer today
Brian Miller
-1972 Nova
-1968 Camaro
-2000 Dodge Dakota
Old 11-05-2010, 04:12 PM
70TWO NOVA's Avatar
finally painted...
Brian Miller
-1972 Nova
-1968 Camaro
-2000 Dodge Dakota
