Old 03-21-2006, 06:48 AM
XcYZ's Avatar
XcYZ XcYZ is offline
Originally Posted by Van B
Not really crappy if you already have the upper and lower A arms and coil over shocks from DSE.
Exactly. Also, if you already have aftermarket brakes for a first Gen, you won't have to worry about changing them because this setup uses the factory spindle. Another key feature is that this frame still maintains the stock track width. So if you already have wheels, you don't have to worry about getting new ones to accomodate the wider than stock track width of the C4/C5 setup that requires high positive offset Vette style wheels.
If you're starting from scratch, then yes, the C4/C5 setup would probably be the way to go, but this at least gives a lot of guys a new option without dumping everything they already have. Personally, on top of all those factors I just gave, packaging is big concern. I need all the room I can get for downpipes - that required a front steer rack. This frame is perfect for where I'm at and what I'm doing with my project.
My LS7 69 Camaro
Old 03-21-2006, 08:04 AM
jonny51 jonny51 is offline
Im not sure about the C5 but doesn't the C4 frame have some bump steer issues?What size wheel can you get with this sub 10"?
Old 03-21-2006, 10:43 AM
fjb2069's Avatar
fjb2069 fjb2069 is offline
Default Are those true coil overs?
I can't tell from the picture, but are those true coil overs or is the bottom of the spring sitting in the a frame? Could a shock wave air shock be installed?
Old 03-21-2006, 10:46 AM
ProStreet R/T ProStreet R/T is offline
Those look like 100% koni coil overs to me.
It appears as though the shockwaves would fit, the only concern I would have is with the clearance around the swaybar endlinks.
Shoot now I'm deciding (in my master pre-purchase planning) if I want to go C5 front end, or with this conventional setup.
Old 03-21-2006, 06:59 PM
907rs's Avatar
907rs 907rs is offline
Yes. They're the same ones you get from Marquez or DSE.
Bill
Old 03-21-2006, 08:42 PM
ProTouringNyC's Avatar
ProTouringNyC ProTouringNyC is offline
Will the global west tubular cat 5 setup work on this
Old 03-22-2006, 07:28 AM
One question Scott.... Since I just picked up my new Wayne Due ALL C-5 suspended sub frame... why you didn't do the C-5 version over the DSE arms?
Old 03-23-2006, 01:02 PM
Camaro ProTouring's Avatar
Camaro ProTouring Camaro ProTouring is offline
Damn that looking so nice!!
Swedish dude who likes old american cars...
This is what i got in my garage!!
Camaro SS -68 "Streetcar"
Camaro -68 "Racecar"
Ford F100 -56 Pickup
Old 03-23-2006, 01:12 PM
fjb2069's Avatar
Good question. ALso interested in the answer to that!
Old 03-25-2006, 11:07 PM
cpederslie cpederslie is offline
Originally Posted by Teetoe_Jones
I've spoken with Wayne about possibly letting us (ATS) offer a bone stock type replacement frame that would use the factory style (or our new 670) steering box, sway bar, upper and lower control arms (with factory UCA pickup points to make use of our tall AFX spindle), and crossmember. I know that the frame is much more labor intensive to make due to the odd angles that the parts mount at, but I feel it will be a largely popular item, and to those who want that updated look, well worth the price..
Tyler
Tyler,
Sent you a PM, and will follow up with an email.
Chad
Thursday Night Garage Association
