Old 06-01-2016, 06:48 PM
64mali's Avatar
64mali 64mali is offline
I started fabricating a panel to go behind the glovebox area of my car where I could mount all my ignition electronics. I didn't want to drill or butcher my firewall so I made this panel and welded nuts where I needed to mount things.
Here's a shot of it installed in the car.
Old 06-01-2016, 06:54 PM
64mali's Avatar
I'm getting really excited to finally bolt things onto the car for the last time. Hopefully. I've been working on the wiring with a good friend of mine. We decided to install a new electrical bulkhead for all the wiring forward of the fire wall. I used a Delfi connector and it will be moved to the outside driver's edge of the firewall where it will be hidden by the fender. In order to get to that area I had to run the wires into the pocket where the air vent was. I am replacing the vent with speakers so I can use the original kick panels.
Old 06-01-2016, 06:55 PM
64mali's Avatar
Got my Centerforce Dual Friction clutch in for good
Old 06-01-2016, 08:16 PM
MOREHORSEPOWER's Avatar
MOREHORSEPOWER MOREHORSEPOWER is offline
You have a lot of good ideas going on here !! I wish we was this far along .
Old 06-01-2016, 09:53 PM
64mali's Avatar
Old 06-02-2016, 11:17 AM
pro66tour's Avatar
pro66tour pro66tour is offline
Fresh wiring looks great going in there! I think I mentioned this before, but love that shot of the rear quarter. I get messy everytime I see it lol
Old 06-02-2016, 01:14 PM
Nice job on the panel, it looks good installed. That's a sweet clutch set up.
Old 06-02-2016, 09:57 PM
64mali's Avatar
Thanks guys. I'm hoping to get the trunk floor finished up this weekend and finish painting the under side. That'll be a huge moment when I can really start rolling on the assembly.
Old 06-07-2016, 05:42 PM
Centerforce's Avatar
Centerforce Centerforce is offline
Awesome! Let us know how you like it once the cars up and running.
Old 06-10-2016, 06:58 PM
64mali's Avatar
Not super happy with the trunk floor pans I got. There's a couple subtle differences like an extra drain hole in the middle and the raised beads on the bottom ran too high in the back. They prevented the pan from sitting flush against the rear cross member. So I had to break out the torch and hammer and flatten them out. Other than that they fit good and I sectioned it in a way that from underneath you could never tell they were replaced. I can make the inside undetectable as well but I'm not going to spend a ton of time on the top because I'm gonna Dynamat the floor.
