Old 06-21-2007, 04:00 PM
V8TV's Avatar
V8TV V8TV is offline
Default Fuel Vent Tube Question
Hey there -
Our '62 Ford has an OLD style fuel vent - a 1/4" steel line that runs from the tank, up the filler neck, and out to the atmosphere next to the gas cap. Now that we're running a return-type EFI system, the returned fuel seems to create some agitation in the tank and the vent just spews vapors as you drive. Aerodynamics make the vapors move forward, so you smell them all the time in the car.
Any ideas on installing some sort updated vent? Charcoal cannister?
Thanks in advance!
- Kevin
Kevin Oeste
V8 Speed and Resto Shop
V8TV
Muscle Car Of The Week
V8 Radio Podcast
All about us:
https://www.v8speedshop.com
Old 06-21-2007, 09:59 PM
Datsbad's Avatar
Datsbad Datsbad is offline
you could use a Fox body 5.0 mustang canister (or any , this size seems to work on most cars), run the vent from the tank to the caniser and the other side to the engine vacuum source somewhere.
Should take care of it !
""DEMON"
6.1HEMI/TKO 5 SPEED
CCW Black edition/BFG tires
Mini tub/AIR Ride
RMS Suspension
CURRENTLY FOR SALE !!!
Old 06-21-2007, 10:04 PM
V8TV's Avatar
That's a good idea, but the vent is behind the rear license plate. This would make for a rather long vacuum line... the canister would have to go under the trunk floor somewhere. Thoughts?
Kevin Oeste
V8TV
V8 Radio Podcast
All about us:
Old 06-21-2007, 10:07 PM
Datsbad's Avatar
Yes it would be long but I think it would help you out.
Most Factory newer cars are like this also .
""DEMON"
6.1HEMI/TKO 5 SPEED
Mini tub/AIR Ride
RMS Suspension
Old 06-21-2007, 10:10 PM
V8TV's Avatar
I guess a 1/4" hardline on the frame rail would do... I have to see if the original fuel line is still there... that would work. Hmm.
Thanks for the idea!
Kevin Oeste
V8TV
V8 Radio Podcast
All about us:
Old 06-21-2007, 10:50 PM
Z-man's Avatar
Z-man Z-man is offline
OK - here's another idea to chew on.
How about just extending the vent tube using some rubber fuel line (or similar) and placing the exit in a more aerodynamic location. Do you smell exhaust all the time? If not, put the vent in a place similar to the exhaust pipe.
1970 Corvette Convertible
406 Supercharged Fuel Injected Small Block
My Website
Old 06-21-2007, 11:03 PM
V8TV's Avatar
That's also a good idea. I guess in the old days, the vent tube allowed for the fuel level to decrease in the tank without creating a low-pressure or vacuum situation in the tank. Now, it is truly a vent, and we smell gas all the time.
However, we don't smell exhaust.
I like the idea of re-introducing the vapors into the engine, and I can program the ECM to activate the purge solenoid on a late model charcoal can, I'll just have to locate it.
I'll do it when we build a small surge tank to fix the fuel slosh starvation issue.
Thanks for the suggestions... keep 'em coming!
- KO
Kevin Oeste
V8TV
V8 Radio Podcast
All about us:
Old 06-22-2007, 10:35 AM
parsonsj parsonsj is offline
You will still need a vent for the same reason: to allow air to replace gas as you drive.
I made a vapor/air separator, hooked it to the tank, then attached the air output of the separator to a K&N crankcase breather filter. Works fine.
jp
John Parsons
Old 06-22-2007, 03:32 PM
V8TV's Avatar
Sounds cool, John. What did you use to make the separator? Do you have any pics?
Thanks,
Kevin Oeste
Kevin Oeste
V8TV
V8 Radio Podcast
All about us:
Old 06-22-2007, 03:43 PM
Kevin,
I made it out of two pieces of aluminum tube, one inside the other. Here's a thread on PT.com with a pic in it (I can't find my own copy any more).
http://www.pro-touring.com/forum/sho...ight=fuel+vent
The breathers are mounted upside down on the underside of the trunk so that any smell would be outside the car. You can see the lines going to them. The other line is the rear housing breather.
jp
John Parsons
