Old 06-27-2007, 06:11 AM
Birdman's Avatar
Birdman Birdman is offline
Default Help me pick a brake setup for the Patriot Dream Camaro!
A company has contacted me about donating some brake parts once I get the setup picked out. I am not too up on 1st gen Camaro brakes, so school me a little. The last two cars I did brakes on were an LS1 Trans Am and a 79 Trans Am with 1LE rotors, which were both pretty simple setups.
The car is gonna be a 67 or 68 Camaro restomod with a Gen III 5.3L and a T56, so I'm thinking 4 wheel discs are in order here.
I need something affordable, since this project is mostly donation based and I'm trying to keep it on budget, but also reliable with good performance.
So throw me some ideas, fellas!
1998 Trans Am - BMR drop springs, BMR LCA relos, Bilstein shocks, Sportmax 18x9.5 wheels, lots of goodies, 6-spd swap, lQ9 swap
1968 Camaro (Patriot Dream project) - Iron LS1, T56, lowered and nitroused PT machine
PatriotDream.org - Help make a soldier's dream come true
Old 06-27-2007, 03:02 PM
QSPres QSPres is offline
Banned
I'd go with the C5 stuff all the way around... Cheap and works well.
Old 06-28-2007, 09:04 AM
Birdman's Avatar
Is that the same sort of stuff as an LS1 Trans Am would have? I have an extra set of front and real calipers and brackets here off of my 98 TA, I could use them for a setup.
Old 06-28-2007, 08:03 PM
Banned
I believe the rears use the same calipers... That's about as far as it goes...
But I know the C5 rotors can be had from NAPA for $27 each...
That gives your budget quite a bit of wiggle room for the rest!
Old 06-28-2007, 09:21 PM
D Rock D Rock is offline
The biggest problem with c5 brakes is the brackets and you must run 17 inch wheels or larger. Keep that in mind. If you need somewhere for the brackets look into touring classics, they are very nice and will hook up you.
Old 06-28-2007, 10:02 PM
Taylor1969 Taylor1969 is offline
Get in touch with Phil at BRP hotrods - www.brphotrods.com
He sells brackets to make stock ls1 brakes work at all four corners. He is a great guy to deal with.
Old 06-29-2007, 05:09 AM
Banned
I got my rear brackets from KORE3 and am running ATS spindles in the front...
Old 06-29-2007, 05:19 AM
Sounds like based on your budget you should go with whichever brakes they are wanting to donate. What are your choices?
Frank Serafine
Old 06-29-2007, 06:29 AM
Birdman's Avatar
Well, we're going with the LS1 brakes. RotorsOnline.com has donated a set of slotted/drilled rotors, my friend Russ came over and dropped off a full set of calipers off of his 98 TA, and another friend has a booster, master cylinder, and partitioning valve for the project.
So all I need is the brackets and we are set to go!
