Old 07-01-2007, 09:10 AM
79cutlass 79cutlass is offline
Default Horsepower Estimation for Cammed 350 Crate Motor
I just bought a GM Performance 350. It has 330hp and 380lb./ft. with a 212/222 duration cam and 9.1:1 compression ratio. I plan on installing a Comp XE268-H cam that has 224/230 duration at 050 inch lift. My exhaust will be full length 1 5/8 headers with 2.5 inch X-pipe exhaust through Super 40s. I will be running a built 200-4r with TCI 2200-2400 converter and 3.42 GN rear for now. What flywheel and rear wheel horsepower would you say I am putting out?
