Old 07-05-2007, 11:12 AM
Payton King's Avatar
Default T56 speedo question...probably in wrong
place.
IS the speedo pick-up on a T56 in generally the same spot as other GM transmissions? My harness plugs right in there, but I want to make sure.
What is the plug for on the passenger side about mid transmission?
Old 07-05-2007, 01:34 PM
Payton-
Here is how the T56 connections break down:
Driver side case, front most connector- C.A.G.S. Do not use
Driver side tail case, small black connector- VSS
Drivers side tail case, silonoid under shifter- Reverse lockout
Pass side case- back up lights.
Hope that helps.
Tyler
Old 07-06-2007, 07:35 AM
Default Thanks Tyler
Helps alot!
