Old 07-08-2007, 10:18 PM
SteveMcqueenRules's Avatar
SteveMcqueenRules SteveMcqueenRules is offline
Default speedway disc brakes
anyone ever use the speedway disc brake kit for GM A-bodies?
the one I am talking about is $239.95
is this kit any good? I wonder if the quality and reliability is there being so dang cheap!
this warning had me sorta worried
You're gonna be hangin' on for mercy when I get this sucker rollin'- FALFA
Old 07-10-2007, 12:55 PM
SuperSport's Avatar
SuperSport SuperSport is offline
There is a simple way to find out the quality. Ask, the dealer if the product is Made In The U.S.A.
That should answer your question.
Old 07-10-2007, 04:06 PM
Derek69SS's Avatar
The reason it's so cheap is because it's incomplete... there's no spindles (your drum spindles can be modified to work if you have a grinder ), no brake hoses, no master cylinder, no prop valve, no booster, etc.
All that it comes with is the parts to mount the rotor and caliper on your existing spindles.
