Old 07-09-2007, 09:54 AM
rich-allen's Avatar
rich-allen rich-allen is offline
Default Fuel system / LS2
I'm ready to buy my tank from Ricks but I need a little advice before ordering.
Is there a fuel line "kit" for the LSx into a 1st gen? if so who makes it.
What in tank pump is recommended for 600+ hp ?
If I decide to add a Nitrous Express system to this motor would I need anything different?
Thanks for the help,
Rich
67 RS/SS
Old 07-09-2007, 03:39 PM
Payton King's Avatar
Default I have a similar set-up
I have a Rick's Stealth Tank with an Aeromotive A1000 inside the tank. Used the Aeromotive fuel regulator as well and just plumbed the lines with steel braided stuff. 10 AN out of tank to filter, 8 AN out of filter to front of car. I actually placed the regulator at the back and my return line is about a foot.
Per the rec of Aeromotive, they will tell you to "Y" the fuel lines before it goes into the rail, and place the regulator at the other end of the rails and run the return back to the tank.
I can try and get some pics of mine if you like
Old 07-10-2007, 06:53 AM
rich-allen's Avatar
Thanks for the info, that will do just fine.
I was hoping somone with a similar setup would chime in and verify what I needed to order.
Rich
67 RS/SS
