Old 07-12-2007, 09:04 AM
kennyd's Avatar
kennyd kennyd is offline
Default F.A.S.T who has done there tuning ?
i need someone who has extensive knowledge in this system . phone #
i have had the set-up programed ,installed ,tuned and still not happy . it runs great after is is started , it will not start when cold ?
i need help and out of time !
Old 07-12-2007, 09:32 AM
You have a PM
Frank Serafine
Old 07-12-2007, 03:17 PM
John S John S is offline
Several questions;
1) Are you running Speed density or Alpha N mode?
2) Doest it take a while to crank then start?
Go into your C Comp software and take a look at your Idle Speed vs coolant temp calibration and make sure your idle speed is set high enough.
Take a look at your Start IAC vs Coolant temp map. You may have to add some more IAC during start to get it to crank over better.
If those look good you may want to look at your timing trim and IAC trims.
Old 07-12-2007, 08:07 PM
TravisB TravisB is offline
Originally Posted by John S
Several questions;
John
Kenny and I will be out of town this weekend I will have him check this on tues when we return he may want to call you.
Thanks For your help
Kenny Davis Hot Rods
Old 07-14-2007, 05:29 AM
deuce_454's Avatar
I had to install a small lead cell batery with a diode, right next to the box on an electromotive installation.. when the engine and batery was cold the voltage dropped below minimum voltage while cranking so it never fired... the batery supplied 12volts to the fmu while cranking, and it got recharged when the engine ran...
id chect the viltage while cranking to prevent you have a simmillar problem, it isnt uncommon for the main voltage to drop to 9-10 volts while cranking with a high output starter and a trunk mounted battery... and at 9 volts your f.a.s.t. is as dead as a doorpost.
Jake: Hit it.
Old 07-15-2007, 03:17 PM
this is good info we just put a new batt in because that was an issue. I wonder if we shouldnt look into this more. Again kenny will be back online tues I will have him read this
