Old 07-15-2007, 03:55 PM
ItDoRun's Avatar
ItDoRun ItDoRun is offline
Default Roof Skin Insulation
Can/should roof skin insulation be placed between the roof skin and braces on a 1st gen Camaro? I'm getting the roof skin replaced and thouht that I would o ahead and insulate it while it was off. I plan on sanding the EDP off and spraying it with epoxy primer and possibly some undercoating. Then I was thinking of putting isulation between the skin and braces. What does everyone think?
Chris
Old 07-16-2007, 03:50 AM
astroracer astroracer is offline
Leave the EDP alone. There is no need to sand it off. IF you have to prime it simply scuff it a bit with ScotchBrite and shoot the primer. I would insulate after the installation. There is no benefit from going under the braces and you will see no difference in sound quality.
Mark
"Bad Ast" Astro Van Pro-Touring Project.... Heat, beat, file to fit, paint to match...
