Old 07-17-2007, 05:01 PM
STOCKTON STOCKTON is offline
Question 502 Question
I just bought my 502/502 from chevrolet and I need to put a different oil pan to get it to fit.
What oil pan do in need?
What are the best engine mounts to buy. I want something strong.
Thanks for the help.
Chris
Old 07-17-2007, 05:44 PM
I don't know what car you have but Moroso, Milodon, or a gm 4 qt should set you up. That should be a Gen 6 block.
Old 07-24-2007, 10:28 AM
HRBS's Avatar
HRBS HRBS is offline
GM Performance makes a 4qt pan made to fit early Chevelles and other Full size cars such as the mid 60's Bel Air, Biscayne and Impalas.
Kit comes with a new oil pump, shaft, gaskets etc.
HRBS on Facebook
Old 07-28-2007, 12:06 AM
what are you putting it in does the car need a front or rear sump. mounts id go with urethane or soild if you can handle the ride.
Old 08-09-2007, 09:41 PM
Impala TT Impala TT is offline
I've used GMs shorter replacement pan a few times and it has worked great! My current project I opted for a STEFFS pan, It looks AWESOME if you want the fabricated aluminum look! They are available through Jegs
Brent
Old 08-10-2007, 06:05 AM
tomspo04 tomspo04 is offline
I used the Milodon 7 qt. Fit well, looks good...no problems.
1970 SS (L-34) Protouring Camaro, 502 RJ, TKO 600 W/aluminum drive shaft, 3.42 rear, C5 ZO6 brakes front & rear, Hotchkis TVS, Boze Mesh; (17X9.5 275-40) & (17X11 315-35), Rick SS fuel tank W/pump, March Ultra serpentine setup, Hiedts/GW UCA's & LCA's, MagnaFlo 3" SS exhaust w'Xpipe.
