Old 07-18-2007, 03:40 PM
Tim Baillie's Avatar
Tim Baillie Tim Baillie is offline
Default Small block conversion questions
I have the buick 3.8 V6 in my 86 Regal. I have a GM crate motor to put into it with a Turbo 400 tranny.
1. Which engine mounts do I need to get it in there ?
2. Which tranny crossmember do I need ? (need one for dual exhaust too)
3. Will I need a different driveshaft ? (the car has the crappy 200 in it, not the 2004r or whatever it is)
Any other tid bits of info you can offer would be great.
www.hotrodderjournal.com
Old 07-24-2007, 08:36 AM
go to any auto parts store and get the v8 motor mounts they should bolt right in. the tranny crossmember go to a junkyard for that any one from a g body should fit. youll need a new tranny mount too the driveshaft yes have one made or junkyard one and replace the ujoints. if you dont know what a g body is heres a list http://en.wikipedia.org/wiki/GM_G_platform_(RWD)
