Old 07-19-2007, 10:53 AM
jannes_z-28's Avatar
Default Awake from hibernation
After some work with the dashpanel and rewiring the relays and fuses I just had to try to start her today. Waiting for the fuelpump to prime I hit the starter and the engine came to life instantly.
There is still some wiring to the instruments to do and a few small things to fix before I can drive her but soon, very soon....
After getting the centerdash in place I found out that there is a lot of space behind the panel So I moved all the relays there, this gave me space to fabricate a small glovebox. Half of the glovebox contains the fusepanel and the other a small compartment. The wormnest of cables will be cleaned up.
Relays in the console, fuses to the left in the glovebox and to the right a small compartment. Everything will later be covered with some upholstery. But that will be a winter project.
I have a few carshows/autocross events that I must attend to in August so I have to be running by next weekend. I have to drive for a couple of days to sort out eventual bugs before going to the first event which is a 300 mile roundtrip.
Jan
Jan Suhr
Stockholm, Sweden
'69 Camaro Z/28 LS1/T56
Old 07-19-2007, 11:22 AM
61Bubbletop's Avatar
61Bubbletop 61Bubbletop is offline
Lateral-g Moderator
Congrats Jan! Very nice packaging....hearing it run is always an exciting experience!
