Old 07-20-2007, 12:11 PM
BRIAN BRIAN is offline
Default Free Sheetmetal Tools
These are 2 old machines weighing about 500lbs each. You will have to be able to load onto your truck without damaging my property. No you can't do it by yourself unless you have low trailer. I will provide an engine crane for assistance.
1. Chicago 36 regular brake. Used to do 16 gauge but now only does up to 18 full sheet. Nothing broken, but needs adjustment? Will do smaller 16 ga sheets.
2. Pexto 36 shear. I broke kick in 1/2. This is older model with cast kick. I fabbed up new kick but it was done quickly and still needs work. It will not cut a full sheet of 16ga as is. It will probably do A 18GA. Needs: adjustment, 1 return spring (went into wall), and blade sharpened. Not junk and easily worth $750 with kick sorted.
Both located as of this weekend in Nassau County Long Island for pick up only. I would like to see young guy or gal new to sheetmetal work get them rather than being resold on EBAY for a quick buck.
I have several newer machines and just do not have time or space.
Send PM with your name and number and I will respond ASAP.
Old 07-20-2007, 02:37 PM
Cyclone's Avatar
Cyclone Cyclone is offline
Wish we were closer to you!!!
Old 07-22-2007, 03:30 PM
Both picked up today.
Thanks,
Brian
