Old 07-28-2007, 03:45 AM
Sicmaro Sicmaro is offline
Default HELP HELP!! tank pressure!!
ok, so my vent hose is sparying gas out of the tank. i start driving and after a short time it starts coming out. if i leave the car running and get out and take the gas cap off it stops coming out of the vent. i understand it releasing the pressure. what i dont understand is why there is so much pressure that it is coming out the vent hose.
ricks hot rod gas tank with in=tank pump. using a vette filter/reg. and this is a 72 camaro with an ls6
any help would be great!!!!!!!
sorry if this is in the wrong forum.
72' Camaro LS6/4L60E
71' C-10 5.3L/4L60E
https://lateral-g.net/members/camp/
Old 07-28-2007, 08:10 AM
camcojb camcojb is offline
Is there a vented gas cap that fits that tank? I had one with my RV tank and it worked perfectly. Otherwise you need a better venting system, maybe a canister like the factory used to contain the fumes and allow proper venting.
Old 07-28-2007, 08:12 AM
69bird 69bird is offline
I had the same problem with my tank. The quick fix is to cap off the vent line and drill a small hole in the gas cap.
Old 07-28-2007, 11:02 AM
thank you guys. im ganna see if i can find a vented cap? if not ill try the drilling.
71' C-10 5.3L/4L60E
Old 07-28-2007, 10:52 PM
murtah's Avatar
murtah murtah is offline
I just ordered the same tank. If you find a vented cap, would you mind posting the part#?
Thanks,
Jim
Old 07-29-2007, 01:57 AM
i got it worked out! i could not find a vented cap but i did find one that worked with lil modification. i will post the part number and mod tommorow. thanks for the help guys.
71' C-10 5.3L/4L60E
