Old 07-28-2007, 06:55 PM
speedfreak speedfreak is offline
Default E-brake cable clearance problem with Baer Track plus
Has anyone else run into this?
The cable runs under the frame about two inches from it.
This limits how low I can set ride hight.
I'm thinking I will rotate the housing ends on the rear so the E-brake cable rotates downword for more clearance.
Can't put the caliper behind rear because of panhard bar.
What did the rest of you do?
Thanks,
Brian
Check out my web site.
www.screaminperformance.net
Old 07-28-2007, 08:40 PM
We had finished a car a while back that the customer already owned Baers before we got the project. We had to make new caliper brackets reclocking the position of the caliper. Kind of one of the downfalls of that type of E brake system. We made ours with the mill, so I do not have any specs for you When I called Baer, they had nothing, so we went to work. Maybe DSE has something?
Frank Serafine
Old 07-28-2007, 09:16 PM
Thanks for the reply Frank.
My housing ends are just tacked so I can rotate them.
Should get me by.
