Old 07-29-2007, 08:43 PM
Tim Baillie's Avatar
Tim Baillie Tim Baillie is offline
Default Small block pulley and bracket question
I am finally getting around to putting my crate motor (pre 86 350) in my Regal and I want to find a inexpensive but nice looking way to do a serpentine belt conversion on it. I have a high output large case alternator I have to factor into it as well.
Idea's or suggestions ?
I would like to go with a electric water pump if I can...
www.hotrodderjournal.com
Old 07-29-2007, 08:59 PM
A few more things........
Plan on running a carb, will be running AC but not right now.
Would like to have the Alt on the passenger side, but it doesn't have to be...........
Kinda new to alot of this stuff
Old 07-29-2007, 09:51 PM
69Camaro's Avatar
69Camaro 69Camaro is offline
GM Performance Parts has a kit that includes all the accessories... don't know if it is excatly what your looking for, but worth looking at anyway.
http://www.gmpartsdirect.com/results...ges=1&pkgid=49
1969 Camaro
Kore3 Z06 brakes
Hydratech hydroboost
Wilwood master
Ridetech stage 2 with truturn
Forgeline GA3 18x9.5/18x12.0
BFGoodrich Rivals 275/35 & 335/30
Magnum T56
Lots of AMD sheet metal
Sprinkled with DSE parts
Ididit Steering column
GM 376/525hp crate
Moser 12 bolt, tru-trac, 3.73:1
Speedhut Guages
Vintage Air
Corbeau LG1’s
Digi-tails
Ringbrothers
Harwood cowl
Old 07-30-2007, 04:15 AM
deuce_454's Avatar
go to a junkyard and get a complete accessory drive system from an astrovan.. the aluminium bracket bolts right on and costs next to nothing.. and looks awesome once you spend an evening polishing it...
and its the vert same thing both GMPP and stret and performance sells
Jake: Hit it.
