Old 08-03-2007, 04:33 PM
Morten Authen's Avatar
Morten Authen Morten Authen is offline
Default Project - Norwegian 1966 Chevelle BBC Twinturbo
Hi friends, the time has come to start the thread about my project. I have been a member of this forum for some time now. I have'nt been the most active, but I have had some questions and have
received GOOD help....
Now it's time to unweil my plans...
I have a 1966 Chevelle 2 DHT which was sold new in Norway in 1966, the car is not matching numbers and previous owners have done misc stuff to the car. Allthough, the car is in good shape.
Thoughs and ideas have been in my head the last two years, and now I'm pretty sure I have it figured out. I wanted a car that is a daily driver, but that also will perform good, but also want to have it to look pretty original on the outside. The car is NOT intended for the strip. Pictures will be posted as the progress of the project goes on.
Engine :
Last year I bought a ZZ572/620 crate engine, the plans was to use this engine as it is, but my dreams to build a twinturbo setup came to life and that's the way it goes My good friend Vidar Strand at V.S Motor (www.vsmotor.no) will handle the conversion.
I considered a Procharger, and I also thought about NOS, but we went for a twinturbo setup. With almost no load, the engine will run as idle, but when I hit the pedal, the monster will wake up This makes the car street friendly in my opinion.
We will lower the compression to apx 8,5:1 and add two Turbonetics turbos capable of delivering 600hp+ each on a 4-valve engine, but since the ZZ572 have 2-valves per cylinder we will not be able to emty the turbos that easy. We're hoping for 1000-1100hp in the DTS dyno, and the engine will be a mild conversion since it will be used daily and we want it to perform as a daily driver. The ZZ572 is not the best engine to convert, but since I allready have bought it, we will make the best of it. And as said, we are not going to build the ultimate twinturbo engine, just add a little power
The original intake will be switched to a Hogans Racing Manifold intake with small adjustments, and MSD DIS-4 ingnition, Autronic SM4 EFI.
The Autronic EFI system also gives us the opportunity to build a tractioncontrol system on the car, variable boost depending on rpm, throttle, speed, and much more.
More information will follow as the build goes on...
Fuel delivery :
All the neccessary Aeromotive fuel pumps, controller, filters and fittings are in house. I will use a 22gallon fuel-cell in the trunk with sump. All the fittings are Earls, Russel and XRP, and the hoses are Aeroquip AN braided hoses.
Cooling :
A BeCool 700hp kit is invested, and will be mounted properly to force the air through the radiatior. The engine-oil will be cooled by a B&M cooler (BM70297) with fan. Also the transmission will be cooled by a B&M cooler.
Exhaust :
The exhaustmanifolds will be welded by ourselves, the parts are now in house, just waiting for the last parts to be lasercut. We are going to use 316 grade steel.
Custom downpipe that will go over to a 4" oval exhaust system and ending the exhaust with Magnaflow racing mufflers with 5" pipes.
Transmission :
At the time writing we are building the 4L80E that will handle the beating. Alto Red Eagle clutches, more solid inputshaft, Transgo Stage2 shiftkit, +++ and custom work done by RATS. The transmission will be controlled by a Compushift unit. And the torqueconverter that will be used is a Precision Industries 5-plate clutch lock-up converter which will be ordered after the engine has been in the dyno.
Rearend :
The new Moser Ford 9" is home, with 31-spline axles, 2,91:1 gear ratio, and True-trac differential. With this ratio I will be able to cruise down the highway in 60mph at 1800rpms.
Brakes :
Two days ago the brakes arrived. The new Wilwood kit for the 1966 Chevelle. 14" discs all around, 6-piston calipers in front, and 4-piston calipers in the rear, with e-brake. Hydratech hydraulic brake booster.
Suspension :
I have used Air Ride RidePro E before we disassembled the car, and now I have upgraded the system to the new RidePro E2 with the LevelPro option (LEV7000). Air Ride tubular A-arms, and tubular upper and lower control arms.
Hotchkis swaybars in the front and rear.
New standard spindles, new Flaming River steeringbox 12:1, and new coloumn and everything.
Exterior :
At the time writing the body has been acid-dipped and all the rust is unweiled. Two days ago I got new quarterpanels, new drivers door, backplate, and some floorpans.
The car will get a new paint (blue pearl), new chrome, and custom CNC machined emblems.
Interior :
New interior from OPGI, new wide black leather Corbeu CR1 seats, all new electric wiring from American Autowire, electric windows from Electric Life, whole range of Autometer C2 gauges, custom aluminum dash, custom console, and more....
Wheels :
I'm aiming at the Foose Nitrous II 18" wheels all around, will be custom ordered to get the widest tires possible.
Well, this is the introduction of my project, thanks for looking
1966 - Chevelle SS 396
1970 - Lincoln Continental Mark III
1979 - Volvo 242 TIC by V.S Motor
1992 - BMW M5 Touring
webmaster @ www.vsmotor.no
Member of American Car Club of Norway
Old 08-03-2007, 04:36 PM
The Chevelle before disassembly
The body after acid dipping
Old 08-03-2007, 04:37 PM
The frame before sandblasting and delivery to chassibuilder
The 572
Hogans intake
Old 08-03-2007, 04:52 PM
novanutcase's Avatar
What a beautiful and beautifully executed car that will be!
Congratulations!
John
Old 08-04-2007, 12:00 AM
Bandit Ls-1 Bandit Ls-1 is offline
wow thats gonna be one nice car man. i got a question.. honestly, how long did u stare at that intake when u got it in?? lol
1979 Trans-Am Ls1 project
1972 Chevelle 454
Old 08-04-2007, 12:49 AM
That is a sick project! Looks like a great car to start with as well.
Old 08-04-2007, 01:04 AM
I can tell you I have had my eyes on it for a looooong while
Old 08-04-2007, 03:24 AM
jannes_z-28's Avatar
Gonna be a great car Morten
Might be able to see it one day.
Jan
Jan Suhr
Stockholm, Sweden
'69 Camaro Z/28 LS1/T56
Old 08-04-2007, 06:42 AM
kadettcqp's Avatar
kadettcqp kadettcqp is offline
Very nice car! There seems to be quite alot of people from scandinavia in here. Do you have some more pictures of the car as i was before?
Can't wait to see the engine af VS motor has played with it. It sure is gonna be killer!
Old 08-04-2007, 08:00 AM
Rokcrln Rokcrln is offline
That is one great build plan. We have a 30K original mile 67SS396 Chevelle that is in great shape but your plans sound like what my Alter Ego would do if we ever decide to tear it apart. Enjoy the build because when it is done you will be to busy driving it to ever do another build like this
Kevin
LFD Inc.
PS. That intake is a true work of art!
