Old 08-07-2007, 06:14 PM
almcbri's Avatar
almcbri almcbri is offline
Default radiator selection
Would this radiator be suitable for my 68 camaro? Any other recommendations would be great.
http://cgi.ebay.com/ebaymotors/NEW-A...QQcmdZViewItem
My engine is a LSX -350HP
Old 08-07-2007, 07:16 PM
camcojb camcojb is offline
you'll have to weld on your own brackets, and adapt the radiator hose sizes to the smaller units the LSX uses; additionally it's ideal to have both the inlet and outlet on the passenger side as that's how the engine is set up, but no big deal to do a custom pipe or hose for the upper hose. It appears big enough to handle the cooling needs, just realize there will be a bit of fabbing to get it bolted in.
