Old 08-10-2007, 11:00 PM
Bowtiguy Bowtiguy is offline
Default C5 and C6 master cylinders identical???
This one is directed towards a certain GM suspenion guru or anyone else who knows. I have a C5 vette master cylinder installed on my car to run my old C5front brake package. I just finished what I believe is the first C6 Z06 brake upgrade to a 4th gen F-body. Before I install a brake bias bloock to fine tune the system I wanted to know if the bore/stroke of these two master cylnders is equal. thanks.
Old 08-16-2007, 09:40 PM
im not sure try looking both up in a parts catolog see if the part number is the same or not.or ask on a corvette forum.good luck let us know what you find out.
Old 08-17-2007, 08:31 AM
I did check with elway chevy (a.k.a. GO) here in denver and there are two part numbers but this may be a packing change and not a cylinder bore difference. I just want to make sure before I crack open my system and have to bleed it all out again.
