Old 08-11-2007, 12:11 AM
akrapovic's Avatar
akrapovic akrapovic is offline
Default Question on purchase
Hey guys, I'm new and have been lurking for about a month. I am closing a deal for a 1968 camaro next week. I was just curious if you could give a HP estimate for this setup. I'm very new to the game and was wondering what brake conversion is suggested for around $1200. I plan on moving to a 17 or 18 in (maybe 19 unlikely) wheel down the road. Will an 11 inch Baer disk brake have enough stopping power
Thanks in advance.
* .30 Over 4 Bolt Main Block
* Forged - 1970 350 Z-28 Crank w/one Piece Rear Main Seal
* Comp. Solid Flat Tappet Cam
* Chevy "Pink" Forged Rods
* TRW 10:1 Forged Flat Top Pistons
* Melling Hi-Vol Oil Pump
* Morosso Oil Pan 8 QT/Baffled
* Edlebrock Victor Jr. Alum Water Pump
* Edelbrock Victor Jr. Intack Manifold
* Barry Grant 750 CFM Silver 4 Bl Carb (flows 933 CFM)
* Morosso 1" Phenolic Spacer
* MSD Pro-Billet Distributor
* MSD 6-AL Distributor
* Hooker 1 3/4" Suer Comp Headers
* Dart Pro-1 (Angled Plugs) Heads 2.05 INT/1.60 EX 215 cc Runner & Guide Plates
* Scorpion 1.5:1 Fully Rollerized Alum. Rockers
* Fluid Damper 6 1/4" Harmonic Balancer
* Lakewood Stamped Scatter Shield
* Front Drive Shaft Loop
* Super T-10 4 Speed (Rebuilt 8/00) w/hard racing parts
* Hurst Super Shifter
* Hays Borg & Beck type Street/Strip Clutch Disk & Pressure Plate
* 4 Wheel Stock Drum Brakes
* Grant Steering Wheel
* GM 10-Bolt Rear Housing Posi 4:11 Gears
* Auto Meter Guages
* 3" Aluminized Exhaust
* 2 Chamber Flow Masters
* New Battery
* Front Tires BFG Comp TA 195/60
* Rear Tires BFG Radial TA 275/60
* Polyurethane Body Bushings in 2000
* Polyurethane Sway Bar Bushings & Idler 2000
* Comp Frame Connectors 2000
* Lakewood Slapper Bars
* AM/FM Cassette w/Power Antenna
* Use 20W-50 Synthetic Oil
* Engine rebuilt 2001 - 2002
Old 08-11-2007, 06:28 AM
Need cam specs, unless the cam is stupid big to keep up with those to big heads, to big headers and to big carb, it is not making any power. The good news is you have a great top end for a future 400CI upgrade, but all that stuff is way to big for a 350CI.
180CC heads, A 700CFM to 750CFM (flowing 700 to 750) would be plenty of carb, and 1 5/8 headers would give it some low end torque, where I suspect this thing really suffers. It might sound good when it gets on the pipe at 5000RPMs, but it will be a stone until it gets there.
I hope you wanted the truth.
A BTW, welcome to the board.
Frank Serafine
Old 08-11-2007, 09:59 AM
akrapovic's Avatar
I appreciate the honesty. Should I back out of the deal. I was looking to have a drivetrain that was good to go, not a project. Is there a easy fix to correct the mistakes made while building this motor.
Old 08-11-2007, 11:18 AM
Steve Chryssos's Avatar
No need to walk away. Like Frank said, just get the cam specs. More than likely you are looking at something similar to a classic LT1 350/375 horse combination. An 11" brake will stop that level of power on the street, but you have room for bigger brakes such as 12" If you have difficulty finding affordable, commercially available big brakes, visit the link below for all the answers. Congrats on the car purchase.
http://www.pozziracing.com/cheap_big_brakes.htm
http://www.pozziracing.com/first_gen_suspension.htm
________________
Steve Chryssos
Ridetech.com
Old 08-11-2007, 11:31 AM
akrapovic's Avatar
Thanks so much guys. I appreciate all the help you have given me.
Here are the cam specs provided by comp cam:
COMPETITION CAMS PART NUMBER: 12-513-5
ENGINE: CS 280TLS-6
GRIND #: CS 280TLS-6
INT EXH
VALVE ADJUSTMENT: .018 .020
GROSS VALVE LIFT: .530 .550
DURATION AT
.020 TAPPET LIFT 280 288
VALVE TIMING OPEN CLOSE
AT .020 INT 38 62
EXH 74 34
THESE SPECS ARE FOR CAM INSTALLED
@ 106.0 INT C/L
INT EXH
DUR @.050: 250 259
LOBE LIFT: .3530 .3660
LOBE SEPARATION: 106.0
RECOMMENDED CC VALVE SPRINGS: 950-16
Old 08-11-2007, 02:45 PM
akrapovic's Avatar
Bueller
Old 08-11-2007, 03:01 PM
Well, as expected it is a big cam to for a 350CI. It is going to be a peaky SOB. Should sound like a machine gun at idle with that 106LC, but that makes it even more peaky, a 110 to 114 Lobe Center would make a much broader and lower torque. With all that big stuff (for a 350CI) and that cam, it is going to make good HP up high (7000RPMs) but hideous torque anywhere. Ever ride a 125CC dirt bike? You now will have the Chevy version of that dirt bike. Dead till 5000RPMs, then raise hell to 7000RPMs.
Probabaly a great little drag engine in a CI limited enviroment, but not a good Pro Touring or Stoplight bruiser at all.
Frank Serafine
Old 08-11-2007, 04:28 PM
akrapovic's Avatar
Sigh.....thanks for the info. Will i be able to utlilize my current head/intake setup or should i start fresh and part out. What would you suggest that I purchase/install before i buy the wrong components.
Thanks again, I really appreciate your help.
Old 08-11-2007, 05:28 PM
Well, if you put 400 cubic inches under those heads and those parts, you would have a bad puppy. But that 106LC cam is not cruiser freindly
Frank Serafine
