Old 08-11-2007, 08:40 PM
69x22's Avatar
69x22 69x22 is offline
Default DSE 4 link
I am considering buying the DSE 4 link for my 69, how does it ride and handle compared to their leaf spring kit? Are there better systems out there that will accommodate a 335 tire? Not really interested in having Air ride.
Thanks.
Old 08-19-2007, 10:16 AM
Do some search here. Steve once explained it all wery clearly. It was easy choise for me to choose the leafs after it.
63 Z06
Old 08-19-2007, 11:28 AM
After talking to Frank at Prodigy Customs and doing my research I came to the conclusion that running a G Bar setup was damn near as inexpesive as running the DSE leaf spring setup if you are going to run a 335/345mm. The reason being you can use a stock gas tank and the G Bar bracketry is welded between your frame rails thus not needing the DSE Shock cross bar. Not to mention easier ride height adjustments/shock valving adjustments and from what I hear improved handling and ride.
