Old 08-14-2007, 12:38 PM
jannes_z-28's Avatar
Default Hydraulic clutch adjustment
In my setup with the LS1 and T56 I now have a problem were I need a little bit more engagement in the clutch.
When I set up the brackets and pedal it worked just fine but after that I have added insulation and sound deadening material and last the floormat. all this added up to a distance that prevents the clutch to fully engage.
I have been thinking of modifying the pushrod so that I can adjust it. I will thread the pushrod and put on a heimjoint.
My question is now, have someone done something like it and can share the experience?
Jan
Jan Suhr
Stockholm, Sweden
'69 Camaro Z/28 LS1/T56
Old 08-14-2007, 02:32 PM
Jan-
We do this all the time. We don't thread the pushrod in the master, we just make a sleeve that crimps over it.
I'd be happy to walk you through it, or you can send me your hydraulics and we'll mod them for 75 bucks.
Tyler
Old 08-15-2007, 01:10 PM
Thanks Tyler,
I'll try to call you next week.
Jan
Jan Suhr
Stockholm, Sweden
