Old 08-17-2007, 11:36 PM
Steve1968LS2's Avatar
Default How about a contest? Win valuable prizes.. sorta..
I thought it would be fun to have a contest of sorts. Recently I built a 408 stroker small block Ford engine for my Fairlane. It wasn’t a low buck affair, more middle of the road and what I was thinking was a little guessing game.
Guess the corrected HP and TQ and win a prize. The closest person that guesses will get a few cool prizes from my private stash of schwag. In the unlikely event of a tie I will send stuff to both winners. If there are a bunch of ties then the earliest ones win. The amount your off from either number will be added together. This isn’t ‘The Price Is Right’, so you can go over.
Here’s the basic mix:
1975 351W block
Stroked to 408
Eagle cast crank
Forged Rods
Dished SRP forged pistons
10.9 compression - run on 91 octane gas
Comp Magnum roller rockers (alum)
Comp 7.7 inch Magnum push rods
Comp vertical bar roller lifters (recommended by Stangnet)
Edelbrock Victor Jr single-plane intake
Holley 950 cfm carb (73/73 jets)
Comp double roller timing chain
1 ¾ long tube headers
Mallory Unilite distributor
7 quarts of 30w oil in Milodon pan with windage tray
236/240 .555/.576 110LSA Comp hyd roller cam
AFR 205 heads with ti retainers and their “nitrous port”
Lets see.. helpful info:
The AFR heads flowed
308 intake and 243 exhaust at .600
310 intake and 249 exhaust at .700
154 intake and 122 exhaust at .200
Correction factor was 1.098 (was HOT today)
Anyway, just something fun and winners name and website gets in the story. Oh, “blown up” is a valid guess
Oh, the engine was also tested with a RPM Performer and 750 carb, but the guess is for the vic/950 combo. The contest will run until next Wednesday morning California time, lets say 10am PST.
Most of all, have fun…
Old 08-17-2007, 11:46 PM
mazspeed's Avatar
mazspeed mazspeed is offline
515hp 490 lb
Old 08-18-2007, 01:01 AM
560hp 610ft/lb
Old 08-18-2007, 01:33 AM
almcbri's Avatar
almcbri almcbri is offline
424 HP and 464 TQ
Old 08-18-2007, 01:38 AM
DAWG's Avatar
DAWG DAWG is offline
529 hp
550 ftlb
SIT DOWN _SHUT UP_HANG ON
Old 08-18-2007, 02:59 AM
McssGmachine's Avatar
McssGmachine McssGmachine is offline
560hp
589tq
BRIAN WEST
Old 08-18-2007, 04:25 AM
zcrz zcrz is offline
Hp-565
Tq-515
Old 08-18-2007, 05:34 AM
jpdeuce's Avatar
jpdeuce jpdeuce is offline
528hp/547tq
Old 08-18-2007, 07:47 AM
Steve Chryssos's Avatar
490HP/512FtLbs. Don't forget, boys. Cam lift does not allow for 300cfm intake flow and he's runing a dual plane on symetrical port heads. He does have beter than 75% flow on the exhaust side (relative to the intake side) He's got a good amount of static compression, but he is also running dished pistons. Oh, and the distributor is on the wrong end of the engine.
My guesses are always on the conservative side.
________________
Steve Chryssos
Ridetech.com
Old 08-18-2007, 08:22 AM
I will let you guess again since you must of missed the specs.
Its a SINGLE PLANE Victor Jr.. we did run the dual plane in the pic but this contest is for the single plane and the Holley 950 as stated.
However.. you are right, we put the disty in the wrong place!
