Old 08-20-2007, 02:34 PM
6D9 6D9 is offline
Default 275/40/18 and 245/40/18 BFG KD's.....less than 100 miles!
Man..........I do not want to sell these but I have to. Here is the deal my sub frame is out of alinment and my car is very low. So the 245's up front on 8's is just to wide and rubs BAD(passside). In fact it peeled a good size gouge in the passenger side front tire. Still holds air just fine just shaved the rubber on the outside. The other 3 are perfect. I want some 225/45/18's but freakin BFG does not make them in this tread or I would just get new front tires and I am not running mixed match tires. So I am stuck with either pull all the drivetrain out(not in the cards) and try and get the subframe alined or go narrower tires. I purchsed the tires from tires rack. The fronts got for $227 each and the rears are $246 each. So I have well over $1000 into them with shipping. I will take $700 for the whole set due to the outside gouging on the pass tires. Local pick up only. I am located in Stockton ,ca.
Old 08-20-2007, 03:26 PM
ProTouringNyC's Avatar
ProTouringNyC ProTouringNyC is offline
Are these the KDW-2 new tread pattern ?
Old 08-20-2007, 04:18 PM
6D9 6D9 is offline
No...these are the KD's
69 Camaro
491 BBC
TH400/GV OD
Currie 9"
Rushforth Livewires
