Old 08-29-2007, 06:04 PM
WicKeD_SS's Avatar
WicKeD_SS WicKeD_SS is offline
Default Have a questiong about 502
Hello guys, I have a chance to buy a 502 from a guy that say's it has 800 miles on it. He is asking 5500.00 for it. He states that it has 502 hp but the motor has cast Iron heads..... If im not mistaken the ZZ502 is the 502hp and has alum heads. And the non-zz has cast head's with lower hp. Am I right? Or is there a 502 hp with cast heads? And last question is it worth 5500.00??
I need to give him a call at the end of the week, so I need to find out asap.
Thanks for your help.
-Brian
WicKeD
Old 08-29-2007, 06:09 PM
camcojb camcojb is offline
-Brian
502 hp 502 all came with aluminum heads. Sounds like the 450 HP version or less, and not a great deal at that price. You can buy the one he has for $5788 brand new with a warranty. For $6299 you can get a complete new ZZ502 long block. There are also many other crate motors from other vendors which may be more what you're looking for, but that one you found does not sound like a good deal for a used engine.
http://www.sdparts.com/categories/CrateEngines.aspx
Old 08-29-2007, 09:42 PM
WicKeD_SS's Avatar
WoW, thanks for the help. I thought the zz had alum heads, not cast iron.
Thanks again
WicKeD
Old 08-29-2007, 09:43 PM
TravisB TravisB is offline
pass on it
Kenny Davis Hot Rods
Old 08-29-2007, 09:44 PM
Mizfit's Avatar
Mizfit Mizfit is offline
https://lateral-g.net/forums/showthread.php4?t=10243
Taylor Day
www.mizfitmotorsports.com
[email protected]
Old 08-30-2007, 05:35 AM
comp-spec's Avatar
too much
all 502 zz had aluminum heads
Old 08-30-2007, 04:12 PM
WicKeD_SS's Avatar
Thanks guys for the advise I will pass for sure!
-Brian
WicKeD
