View Poll Results: Which TB is most streetable?
75-78mm mono blade 0 0%
90mm mono blade 4 44.44%
1200 cfm 4 bbl TB 4 44.44%
90mm + TB 1 11.11%
Voters: 9. You may not vote on this poll
Old 08-31-2007, 04:01 PM
TT402LS1 TT402LS1 is offline
Default Which type of TB is most streetable?
I have a Victor Jr. intake, and dont know what kind or size TB I should use. I want something very streetable. Is 90mm mono blade too big? Is a 4 hole carb style best?? How about a smaller mono blade (75mm-78mm)??? Has anyone tried these differnt ones on the same engine?
Thanks - Ron
71 Chevelle w/ LQ4 stroked to 402ci, Twin 62mm turbos, Viper T56 M6, 12 Bolt with 3.42's.
Old 08-31-2007, 05:06 PM
69 L88 Camaro 69 L88 Camaro is offline
Default Throttle Body
I would look to progressive 4 hole first. Then look at the throttle arm and if you can soften the off idle travel by a long arm or a cam type cable actuator.
I don't ride in it, I drive it.
Old 08-31-2007, 05:22 PM
camcojb camcojb is offline
Thanks - Ron
The 4 barrel tb's around 1000-1200 cfm are very streetable. I did go from one of those to a single 75mm monoblade on a Procharged big block, and definitely picked up throttle response. I run the monoblades on nearly everything. As far as size, even the factory uses a 90mm now, so anything up to that isn't too big. The secret is in the tune, but a super large monoblade can cause issues since very little throttle movement gives big increases in airflow. Anything up to 90mm would not fall under that in my opinion.
Old 10-07-2007, 03:47 PM
rocketman's Avatar
Depends on the intake, I had a sheetmetal with dual 90's on it and a brodix with a 4 barrel style fast tb. for your set up I would use a fast 4 brrl style
