Old 09-02-2007, 08:03 PM
Yard Dawg's Avatar
Yard Dawg Yard Dawg is offline
Default Opinion: Main Support or Windage Tray
Could use some advice on whether to use a main support or a windage tray.
I was planning to use both, but they won't fit with the Canton 7qt Road Race pan.
It's a SBF 347 (N/A for now) and it'll be going back into my daily driver.
(We pulled the motor to fix a seperate issue)
I was previously running just the windage tray but wanted to add the support while it was apart in order to strengthen the stock block.
I am also adding a "valley girdle" as well in the event that I add a mild blower at a later date.
It will see some open tracks and a few autox events.
Would appreciate your input/opinions.
Thanks in advance,
Steve
Steve L
Designer/Illustrator
& Auto Obsessionado
"The sooner you fall behind, the more time you'll have to catch up."
